WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 1993-02 Firebird/Trans Am Owners > 93-02 Engine Tech
93-02 Engine Tech LT1 and LS1 motor heads unite!
Old 01-16-2008, 06:39 PM
Velox65's Avatar
Velox65 Velox65 is offline
Send a message via AIM to Velox65 Send a message via MSN to Velox65 Send a message via Yahoo to Velox65
Default Turbo the 3.8 or performance mods
Does anyone here know how to turbo the 3.8 V6 in a 97 Firebird? I have the Turbo but I need input on what else I would need to do, I'm looking for about 5 PSI. Also what are good mod's other than forced induction should I need to go that route. I've looked around but I cant find anything for a Bird or camaro at that matter.
Any help whatsoever will be appreciated
Travis
"The only Substitute for Cubic Inches is Cubic money"-My Father
"Never under estimate the power of a well calculated Ass-Kicking"
Our's is a world of nuclear giant's and ethical infant's, we know more about war than peace, more about killing than living.
Old 01-21-2008, 06:38 PM
73GA 73GA is offline
I bet with what you'll spend on the turbo setup, you could sell the car and buy one with an LT1, and probably make more power than stock. The mustang guys around here told me about a v6 turbo mustang the guy dumped loads into, and he still got beat by a stock GT. Even he said he should have sold it and bought the v8 car. just my .02.
You'll need a turbo manifold setup...will probably have to be fabricated, oil feed and drain lines to the turbo, a waste gate to regulate boost, a blow off valve to drop boost when the throttle closes, probably bigger injectors, definately a special MAP sensor to read boost, a computer setup to properly tune the fuel curve, an intercooler is a good idea, all of the associated plumbing will have to be fabricated, a down pipe and exhaust work to graft it in, ROOM is a biggie, I've probably left alot out and as you can see it gets expensive really fast to do it right. best of luck
Old 01-22-2008, 06:32 PM
Velox65's Avatar
I looked into it and I'm not going that direction, looking for just bolt ons and the like.
Featured Vendors
Advertising Info
