Old 09-19-2010, 10:30 AM
Conundrum Conundrum is offline
Default Waste of time?
I picked up a 400 to put in my 74 GMC pickup project, and after a little searching I discovered that it is a later 500557 block. I am not going for strip hero status or anything, just a strong street truck. Am I going to waste my time with this block, should I find an earlier one?
Old 09-19-2010, 11:38 AM
chupiw1 chupiw1 is offline
I'm no expert by any means, but if it doesn't have any cracks, and if it checks out fine with a sonic check, go for it. You aren't going for an all out race build, I would think it would work out fine.
Old 09-19-2010, 11:46 AM
chiphead's Avatar
chiphead chiphead is offline
The 557 blocks are good for about 400+HP with the stock stroke crank. They aren't good for strokers, because of the extra loading on the main webs with the larger stroke. No NOS or forced induction either. Truck duty should be fine.
Old 09-19-2010, 01:20 PM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
I looked for a "good" block within reasonable shipping distance and couldn't find one so I decided to do my build on the stock 557 block that came in my '76.
What I did do to give me more of a safety margin was to lighten the reciprocating assembly as much as possible. I used Ace's 4340 Ultralite I-beam rods and SRS forged pistons. The rods alone were worth about 250 gm each, add in the lighter pistons and pins (don't know the weight but substantially lighter than stock) and the a re-balance of the assembly took a lot of weight out of the crank counterweights. By all accounts, I should be at a power level of about 450 - 475 hp with my heads and cam combo. I haven't had a chance to dyno it yet unfortunately.
Even with these light parts I'm still going to keep my red line at 6000 and the rev limiter set at 6250. The power range of the cam is 2600 - 5600 rpm so 6000 for a redline is more than enough.
Am I concerned about the "weak" 557 block? Not in the least. Even if I hadn't used the lighter parts, a properly built 557 block with good rods should live a long time in street car. By the same token, I probably wouldn't use the 557 block as the basis for a max effort 10 second motor though.
Unless you have the intentions to hit the motor with N2O or a blower of some sort or just rev it to the moon, I'd build the block you have and enjoy the ride.
JMO, Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
Old 09-21-2010, 12:13 PM
Thanks guys.
Although my rebuild may be a ways down the road.
Old 09-21-2010, 12:49 PM
Ragtop Man's Avatar
Ragtop Man Ragtop Man is offline
Break it? I can't even lift it.
Great idea for a swap, a total forehead smacker.
If the 400 made it this far, it will be fine. Glad to see some Pontiac power going into a GMC, should have kept it there to separate them from Chevy.
Old 09-21-2010, 12:57 PM
GREATGTO's Avatar
GREATGTO GREATGTO is offline
I have one thats been together since 1992, street strip use, runs high 12's, makes about 420 hp
Car Craft Garage.
Automotive Restoration
Old 09-21-2010, 02:42 PM
amcmike's Avatar
amcmike amcmike is offline
JMO, Stewart
Do the half-fill on the block would help too, wouldn't it?
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 09-21-2010, 02:58 PM
Murf'sDad's Avatar
I asked the same question last year and was told the block fill stabilizes the cylinders but does almost nothing to strengthen the area of the mains, where the problems can occur.
Stewart
Old 09-21-2010, 03:17 PM
steve's Avatar
steve steve is offline
i just put my 500+ Hp "557" in service this summer. still holding strong !
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers....
Old 09-22-2010, 03:39 PM
MandevilleBird MandevilleBird is offline
Butler Performance advise that these blocks are good to 600HP.
Old 09-22-2010, 04:15 PM
Murf'sDad's Avatar
... with proper preparation and Mag'ing, sonic testing, good parts, fine blueprinting, etc. Try to short change the work and you'll end up with an iron paper weight very quickly at that power level. Course that's the outcome with almost any block where short cuts are taken, details are neglected and inexpensive parts are used.
Stewart
Old 09-22-2010, 04:33 PM
HO LEMANS's Avatar
HO LEMANS HO LEMANS is offline
Default 400 in a GMC
Hey just wondering if you needed a bell housing for that 400 in that pickup ?? I had a 73' GMC 4WD with a 400 4spd in it and I can tell ya it was a blast to drive I still have the lead pipes for the dual exhaust for the 400 in a pickup with factory manifolds as well laying around here somewhere. The bell housing was machined out to accept the larger front bearing retainer (of a truck 4spd)with a boring head so it's really accurate and surprisingly the clutch linkage hooked up fairly easily as well as the rad hoses let me know if you want any of this stuff and I will locate it for ya
NEVER DRINK DOWN STREAM FROM THE HERD
Old 09-22-2010, 04:52 PM
77 TRASHCAN's Avatar
A thorough checking of a 557 block, for a good running street engine should be all you need, as in magnafluxing.
A good visual inspection would be important to me also. If you have a good air compressor, a die grinder, and a box of those sand paper rolls, you could de-burr the whole engine, including the main web area. It might be a waste of time, but would be cheap insurance. Cracks start from thin metal, or sharp edges. If you knock them down, it's cheap insurance...
When I get to work on one of my 557's, this will be my plan of attack...
Shut it off
Shut it off
Old 09-23-2010, 06:34 AM
I have not decided what trans i"m going to use yet, the truck was a manual so all the pedals and linkages I have. But I was thinking of using a 2004R, i've got one from a 84-5 T-Type. And the engine came with a turbo 350 so I could always use it.
When I get around to building it, i'm going to do this for sure.
Old 09-23-2010, 09:20 AM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
my 557 has had the snot beat out of it for the past 8 years. I really do beat on it. It has 2 speeds, idle and WOT.
You will be fine...
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 09-25-2010, 08:26 PM
Thanks for all the replies.
I have another question, i'm going to put this in a 74 GMC and was wondering what color the pontiac engines were in 74?
Old 09-25-2010, 09:02 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
I beat the total snot out of my 557 with stock rods and heavy trw forged pistons. I even supercharged it for awhile. The motor now serves as the spare until I get it in my red 81, it's still going strong.
As for paint, it's awfully hard to beat that classic blue metallic in my book. You can paint it chevy orange and tell people it's a special wide block 350...
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
Old 09-26-2010, 02:39 PM
I like the blue metallic best
Old 09-27-2010, 06:27 AM
Well I almost had an early 70s f-body 160mph speedo bought on ebay lastnight, for less than $20 including shipping. As i'm sure we all have seen, I lost out in the last few seconds. Of course it didn't help that I was using my phone and it takes forever to load anything, so i'm a little bummed about that. Maybe the 8k tach i'm watching will work out a little better.
