Old 12-30-2011, 07:15 PM
lugnutt's Avatar
lugnutt lugnutt is offline
Send a message via MSN to lugnutt
Default Sheet metal style water cross over
Don't know if this is a production piece or not. Do you know anyone that sells a fabricated water crossover? Just really hate the look when you cut the front of a intake off.
If its one thing I know, its..... Uhhh I forgot .
What do you mean I couldnt be the president of the United States of America, Its still WE THE PEOPLE, RIGHT!!
Old 01-02-2012, 07:20 AM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
Lugnut, just build it yourself, its easy.
Old 01-02-2012, 09:21 AM
60man's Avatar
60man 60man is offline
Happy New Year Lug...
Bigchief468 is running a KRE sheet metal intake...and has a sheet metal crossover on his old motor...
Maybe you coluld check with Jeff/KRE. There is a picture of it in Performance For Sale section under NSS...
Got any 6.7 rods ??....:-)
ECM member.
MANDRA
Old 01-02-2012, 03:37 PM
Ron H's Avatar
Ron H Ron H is offline
I added an old warrior crossover someone divorced long ago. KRE sells new cast pieces.
68 Firebird
Are you running with the wind or breaking it?
Old 01-02-2012, 04:08 PM
EPC_Motorsports EPC_Motorsports is offline
sonny leonard ''SONNYS'' Located in Lynchburg VA.
Old 01-02-2012, 08:20 PM
lugnutt's Avatar
Thanks all, I think Ill try Sonnys. I looked at KRE, didnt really see anything there. I may end up making one, I just wondered if someone had one "off the shelf"
Happy New year to you to Troy. How are you feeling? I hope all is well. Maybe see ya at the track next.. I mean this year if all goes well.
I do not have any spare rods. Are you looking for aluminum or steel?
I do have a spare Nod iron crank lightened and balanced for aluminum rods.
Old 01-03-2012, 12:22 AM
60man's Avatar
I'm starting to feel better these days....a good thing !! Hope it continues..
Just thinking ahead for aluminum rods for the 4.5 crank in the future..I assme 6.7's...let Jack call it...
Hope to catch ya at track...
ECM member.
MANDRA
Old 01-03-2012, 05:39 PM
GoatDr GoatDr is offline
Here is Kauffman's. Scroll down a bit.
http://www.krepower.com/Pontiac%20Intakes.htm
GoatDr
Old 01-04-2012, 12:29 AM
60man's Avatar
I know KRE makes the cast crossover....But Bigchief468's intake & crossover (sheet metal) were made by KRE also...
ECM member.
MANDRA
Old 01-04-2012, 09:57 PM
Ron H's Avatar
I am sure they make a sheet metal crossover, it is just not listed separately on their site. They show one in the picture of the sheet metal intake as well.
68 Firebird
Old 01-05-2012, 03:50 AM
john marcella john marcella is offline
Remote water manifold! I will post pics tomorrow. Way better way to go.
Old 01-07-2012, 10:08 PM
huddie huddie is offline
I am interested in the Pic and the idea of the remote water manifold.Thanks
Old 01-07-2012, 11:03 PM
This is one of my 4 into 1 water manifolds. It's set up for 4 #10 o-ring fittings (but you can use a combination fitting that is up to #12) and 1 #20 o-ring on the opposing side.
I also make a 2 into 1 water manifold. It uses 2 #16 to 1 #20.
Both have provisions for NPT for water temp pick up.
Old 01-08-2012, 02:02 AM
60man's Avatar
Interesting...is this something you make?..sell?
Could be used to pipe water from both ends of heads..
ECM member.
MANDRA
Old 01-08-2012, 03:51 AM
Yes,yes and exactly. $135 No fittings, but they are not to much.
It packages way better and looks so much nicer, radiator hose is only about 4-6 inches long. And you can pull water from where ever you want!!!! If i get a chance i will take pics of my set up.
Old 01-08-2012, 12:54 PM
grandville455's Avatar
grandville455 grandville455 is offline
VERY NICE ! I would love to see pics also!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 01-08-2012, 08:36 PM
60man's Avatar
Cool....would like to some pictures of your setup showing the water temp probe too...
ECM member.
MANDRA
Old 01-09-2012, 01:50 PM
lugnutt's Avatar
Default Manifold
That looks nice. Does the maniflold just hang there by the support of the hoses, or is there a mounting bracket? Do you make these? Do you stock these?
Old 01-10-2012, 11:28 PM
This is my set up, its old-before the 2pcs billet design. I am picking up water between the middle exhaust ports.The water temp is in the middle of the water manifold.
Old 01-10-2012, 11:32 PM
quick67bird's Avatar
quick67bird quick67bird is offline
If we would like one of these manifolds how do we go about ordering one from you John?
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
