| 93-02 General Tech/Discussion 1993-2002 Firebird/Trans Am General Tech/Discussion |
05-07-2013, 08:20 AM
Power Windows
They go up rather slow. Both do. Is this normal? I can believe that both motors would go bad at the same time. Been like this since I bought the the car earlier this year.
05-07-2013, 09:30 AM
MY 10000 mile 2000 Ram Air Conv had the drivers side lockup a few years ago . Cheap parts tend to do that. Really nothing more to say.
05-07-2013, 02:02 PM
It is not the motor going bad, but the diode that keeps the window from crushing a body part that is going bad. When the motor is under a load the diode heats up and cuts the power to stop the window from working. As the diode ages it doesnt work as well. You can cut the diode out and wire the motor without it and the windows will go up and down Really fast, but you also loose the safety feature. Or just replace the motor with a new one.
1971 Trans Am - Sold
1977 Can Am - Sold
2002 Trans Am Firehawk - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
1972 Trans Am - Sold
1970 Trans Am - Current Project
05-07-2013, 04:35 PM
Based on feedback, is it safe to understand that the motors are going bad?
05-07-2013, 05:10 PM
Short version the window motor unit as a whole is going bad.
1977 Can Am - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
05-07-2013, 09:43 PM
Ok, if I have the door panel of (fixing the pre-panel crack issue), I might as well replace the motor. Who has a decent motor and not ebay junk.
This is one reason why I want to sell the car. The whole thing as a whole just seems fragile. Maybe its just me.
05-09-2013, 09:52 AM
Administrator
They go bad in every single firebird. Honestly, GM replacements are no better than some other overseas ones. And cheaper too. You can do both sides for probably $50-75 bucks.
We sell GM ones, but we can get you the other ones as well
"LIKE" Max Performance on Facebook!
"LIKE" Cold Case Radiators on Facebook!
"LIKE" GTOG8TA.COM on Facebook!
05-09-2013, 12:15 PM
I'm happy with the one I bought from Oreilys.
05-10-2013, 08:11 PM
the car has about every option you could get.
some stuff lasts longer but all in all they are a real fun ride.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
05-10-2013, 11:43 PM
Windows will have to wait now. The fuel pump went out yesterday and thats gonna hurt the old wallet a bit.
05-11-2013, 07:26 AM
Ive had alot of fuel pump problems(not just 4th gens) from the gasahol crap and cars that sit for extended periods. that said,on beater 4th gens(yours not included) I cut an access panel to replace and it then turns into a 30 min job.
05-11-2013, 10:09 AM
I was reading where quite a few people have done that. I don't want to but even if I did the vert has a different floor and I wouldn't know where to cut.
05-12-2013, 08:27 PM
agree I ve done this to hardtops only
I used a wrecked parts car I have to explore where to cut.
really trying to understand why GM didnt do this like they have on some other models.
FYI last pump I replaced was $25 with lifetime warranty.
Im sure a dealer wants at least $800 to replace
05-12-2013, 11:25 PM
Not sure where you got one for $25. Even Rock Auto was about $200 on the average.
05-14-2013, 08:07 PM
just replaced the pump not the module
05-15-2013, 04:39 PM
they do both go up slowly, there are kits out there to help, from what I remember its because the power supplied to the motors is choked so they are slow.
its a big window
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
05-15-2013, 04:41 PM
I have seen a template around one of the other forums
check ls1lt1 or ltxtech or even ls1tech
05-15-2013, 11:26 PM
Tried that. No luck for a vert. Its too late now anyway. The back of the car is in pieces now.
The good part about this is new Magnaflow exhaust is going on.
05-16-2013, 08:41 AM
I always use the excuse of having the car apart to get new parts, haha
05-16-2013, 07:05 PM
I had a 3 inch duals Pypes system on my 02
didnt fit right tho,probably too big?????
98s used a single 3 inch tho
