I always thought that big-car rear axles were essentially the same from '65 to at least '70, but recently had someone tell me that a '66 axle is wider overall than a '65 axle. Doesn't sound right to me. Can anyone shed any light on this? Thanks!
Same. Check the other threads in archives. Entire assembly is identical '65-6. Axles will pull out and stick in to either one. '65-70 internals swap except for '69 GP.
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress 2005 GMC L-33 |
same ...
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console 1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats 2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather |
Yep 65-66 direct swap.. 67, 68-70 housings vary. gears swap freely 65-70 though
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a 66 Star Chief Executive 59k mile 389 67 IH Scout project 2WD "Indian Scout" 69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2008 Saab 9-3 2.0T convertible |
Hi Larry
Not trying to hijack this thread, just wanted to thank you for the lead on the 3.08 posi carrier & gears. Worked out GREAT ![]() Thanks, Ron
Another Red Light Nightmare ![]() 1966 Martinique Bronze 2+2 428 tri-power auto, black top & bucket seat interior, pass recliner, ATC, Cruise, AM FM, Reverb, Wood wheel, tilt, ps, pb, pw 1966 Catalina, Barrier blue with a white vinyl top, tilt, AC, ps, pb, bucket seats with console 68 428 4 bolt, 4 speed M20 and a 66 tri-power project. Semper Fi |
| The Following User Says Thank You to Rapdron For This Useful Post: | ||
FWIW: the pinion seal shows a different part number for the 65 and the 66 to 70. I've never compared the seals to see if there is a machining difference in the carriers or not...
65 Bonneville Brougham 4DHT 65 Grand Prix 2DHT......now parts 65 Catalina 2+2 2DHT 65 Catalina Safari 4DSW |
The pinion seal started to leak some time later and my diff guy was having difficulty getting a seal. I would assume he was looking for a '66 seal and I never told him it was a '65 diff. He eventually solved the problem but its something to keep in mind for the future. Thanks Ian ![]() ![]()
To laugh at men of sense is the privilege of fools. |
| The Following User Says Thank You to Heybuck For This Useful Post: | ||
Rock Auto calls for SKF 19310 for '65 and SKF 19273 for '66. They are definitely different. Here are the specs:
http://www.rockauto.com/catalog/more...228&cc=1350234 http://www.rockauto.com/catalog/more...254&cc=1350111
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
| The Following User Says Thank You to Bill Hanlon For This Useful Post: | ||
