Old 08-06-2014, 09:53 AM
71ModelJ's Avatar
71ModelJ 71ModelJ is offline
Default Fuel gauge
Does anyone know where to get a new fuel gauge for a 71 grand prix. Also do you have to take the whole dash out to replace it. thank's
Old 08-07-2014, 08:40 AM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Yes the entire padded dash needs to come out. The gauge can come out from the backside of the cluster but first you would have to remove the printed circuit.
I have good used gauges here or if you wanted to send me yours I can rebuild that one for you.
Peter Serio
Owner, Precision Pontiac
Old 08-07-2014, 01:20 PM
Scott Thelander's Avatar
Default also
I am guessing........ but you have already eliminated a ground issue at the tank and the sending unit as not being the problem....
does the gauge not move ? or read way full ??
trying to save you pain from removing the dash.........
and as a matter of fact I am pulling a 69 J model pad here in the next several days
and can take step by step pics........
its been 25 years since I pulled a 69 sj pad ... I know theres a couple bit?h bolts
can anyone verify the position of these ... seems they wer e near the radio
and how to get to them ??
Scott
Old 08-08-2014, 01:53 PM
It's been a long time but as I recall you had to first remove the driver's side A/C vent outlet and in behind there is a 1/2" hex headed bolt that points to the left.
Also up underneath the radio lower dash to the right there is another brace with the same sized bolt.
Peter Serio
Old 08-21-2014, 09:03 PM
71ModelJ's Avatar
Scott
Sorry I didn't get back right away. Vacation needed! But yes replaced sender and made a better ground. Unplug goes to full. Half a tank reads 1/8th. Fuel guage low and high resistance sides. I'm thinking guage.
