Old 01-24-2018, 08:55 PM
Dave M's Avatar
Dave M Dave M is offline
Default Cam ID help
We took this cam out of the 400 that used to be in my 68 Firebird. Any idea what it is? I assume the 292 is the duration and the “H” is for hydraulic?
Old 01-24-2018, 09:01 PM
ponyakr's Avatar
ponyakr ponyakr is offline
Yeah, a CC 292H10 should be a Comp Cams 292 Magnum.
https://www.summitracing.com/parts/c...w/make/pontiac
That cam should be REAL nasty in a 400, especially without Rhoads lifters.
Old 01-24-2018, 09:09 PM
Dave M's Avatar
Sounded real nasty. But had no torque with #99 heads. Didnt get going until you got over 3k.
Old 01-24-2018, 09:13 PM
Dave M's Avatar
Old 01-25-2018, 01:52 AM
Old Man Taylor's Avatar
The 10 is a 110 Lobe Separation Angle (LSA)
Old 01-25-2018, 01:56 AM
Dave M's Avatar
Thanks Jim. Like I said, the thing sounded like a real beast. But wasn't, due to having 8:1CR, small valve heads, a real small exhaust, and a stock converter. The thing ran real hot too. It's getting a complete rebuilt now. Going with a roller cam and #670 heads.
Sent from my iPad using Tapatalk
Old 01-25-2018, 07:21 AM
steve25 steve25 is offline
You would get better overall performance by porting your heads and running a Cam a tad on the small side of what you think you need!
That 292 Cam with less than 9.8 comp in a 400 must of been a supreme Turd?
Old 01-25-2018, 12:46 PM
Dave M's Avatar
Was horrible to drive and try to tune. Going with 230/236 .510/.520 112lsa HR. And 9.6CR
Old 01-25-2018, 02:18 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I have a 292/286 in my RAIV 400 on a 110. Pretty choppy idle but runs power brakes fine.
Skip Fix
