| Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Performance parts Like new
Located in Charleston SC 455 rotating assembly, 60 over Ross forged pistons (XL421P), GRP billet aluminum rods (33976), stock 455 crank 4.210 stroke 3.25 main (496455). $1450 72 455 block with billet 4 bolt main caps and ARP studs, broken lifter bore, had a high lift solid roller and no brace will sell just the caps with or without the block I just thought someone may be able to fix it $300 Moroso deep sump oil pan 8qt capacity with pickup $175 Victor edelbrock intake, dominator flange $295 Billet thermostat housing $25 SCAT SFI approved flexplate $50 Front Engine plate $45 Aluminum valley pan no pcv $40 Roll master double roller timing chain, multiple key ways $75 Comp cams solid roller cam 306C-R8 QB4813 $75 Hedman Hustler Round port headers from 70s Ventura $150 I will add some more performance parts as I pull them out and get pics |
How much for the caps and studs ?
$300, just throwing the block in for free if you wanted it but I realize shipping the block is expensive so I’ll pull the caps and ship them and junk the block if need be
| The Following User Says Thank You to ddella22 For This Useful Post: | ||
Any pics of engine plate? Thanks in advance
Rob |
Is the timing chain new? Pics of the flexplate and thermostat housing please. Interested in all 3
Everything had 8 passes on it until the lifter bore broke, pics attached
Any pictures of the rods and pistons from the other side? Maybe a close up of a rod and piston? Is the crank standard? Part number? Oil pan and pickup pictures? Whose pickup?
Thanks - Kevin
1972 Firebird 462, 6X heads, RA4 cam, iron intake, Cliff's Q-Jet 3925 race weight Best of 12.88 @ 105 so far |
Crank is cut 10 on main and rod journals 496455 is the part number |
Intrested in the cam, got any specs on it. Post the card if you can.
GT. |
PM sent on the caps
Sorry I don’t have a cam card, all I have is the numbers off the end that I posted and that it’s a comp cams
PM sent
Victor intake, flexplate, and main caps all sold
I will take the cam if blueghoast doesn’t
From what I found the cam is 275/278 .050 with 688/693 lift with 1.65’s. On a 104
The R8 should mean the cam is. Solid Roller ground on a 108 LSA
If it posts the pic here is the cam. Hope it is a 108 because 104 is tight but it a drag race cam.
GT |
Front engine plate sold
