Building a 500” Kauffman high port engine. Pretty big roller cam, 12:5 compression, 400 cfm heads. Most likely will run my old 850s or maybe new 1050s on the Gutsram.
Besides matching the ports any other advice on getting the most out of the manifold? SD |
Open up the run entrance at plenum as much as you can. The divide wall can be thinned quie a bit. Personally i don't like the peak in the plenum floor, i'd remove it and make floor flat. Other than that there isn't much that can be done. You can't make the runners at the plenum big enough and you can't make the plenum big enough. But it'll still make big power and due to things being small it'll accelerate nice in the car.
An engine like that will probably benefit from a spacer underneath the manifold top to increase plenum volume.
What I have found with both intakes on my engine is they both like shear plates.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135 66 GTO (Retired race car) 421 CID Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
We had a hand-me-down sheetmetal tunnel ram on the Grocery Getter and it was notorious for stalling at the end of a big burnout. It had a pretty big plenum.
We switched to the Gutsram and problem solved. So I guess my general thought is to use spacers or something like that (not permanent) so you can try different plenum volumes till it's optimized. FWIW, Eric
Thanks for the advice guys.
SD |
Look at mine, it isn't finished but shows how the center divider can be thinned (maybe don't go quite that much).
