| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Hey guys I have a 65 389 that I pulled out of my 67 Firebird. I don't anything about the engine other than it's been trouble free for the 22+ years I've owned the car. It does have oil leaks and I did replace the timing chain about 20 years ago. Other then that she's a runner. I had it dynoed back in 2015 where it pulled 273.7hp / 358tq. I'm running edelbrock RPM intake Holley 750 and protronics ignition. I do have the cast iron intake but I don't know if it's original. https://youtu.be/UmKDccwIJpU
67 Firebird Convertible |
That is a YE code 325 hp 4-barrel 10.5:1 compression 389 with #76 heads from a big Pontiac equipped with a TH400 automatic.
Not particularly valuable because it’s not a GTO 389. The 389s really aren’t sought after unless they’re from a GTO, and even then it’s the manual transmission engines and especially the Tri-Power engines that people are looking for. Maybe $500 because it’s a good running engine, but a leaker as the majority of older 389s are. If it were mine and I had the room I’d keep it as a good running spare just in case.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following 4 Users Say Thank You to b-man For This Useful Post: | ||
Some one that has a 69 or earlier engine in their car could use it as a temporary replacement to get their original engine redone. From my knowledge, the motor mounts should work from 69 to 65? Bart?
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
| The Following User Says Thank You to 77 TRASHCAN For This Useful Post: | ||
| The Following User Says Thank You to b-man For This Useful Post: | ||
