Old 05-10-2026, 03:49 PM
hutchwareltd's Avatar
hutchwareltd hutchwareltd is offline
Default Distributor Differences Question
I have a 67 GTO 400 with stock manifold and 670 heads. It is a Auto with A/C and AIR. It currently has a 1111942 (1969 FB AT) distributor installed. I am rebuilding the correct 1111250 (1967 GTO AT AIR) distributor. Two questions: Is there any significant difference between the two distributors? The 1111250 needs weights and springs - can I use one of the readily available recurve kits?
Thanks!
Old 05-10-2026, 05:29 PM
LStathas LStathas is offline
I'm not an expert at all on these but I think you'd be best to use your old weights and springs than the newer kits.
Green Bay: A drinking town with a football problem.
Old 05-11-2026, 02:03 AM
Thanks, I was thinking the same. Only issue is that they are missing.
Old 05-11-2026, 03:58 AM
Kenth's Avatar
Kenth Kenth is offline
1967 GTO 4 bbl w/A.I.R. uses the 1111252 distributor.
1967 GTO 4 bbl w/o A.I.R. uses the 1111250 distributor.
Both has the exact same specifications, 26-30° @ 4400 rpm. 6° initial.
1111942 is a 1969 350 2 bbl A/T distributor with max 22-26° @ 4800 rpm. 9° initial.
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 05-11-2026, 12:52 PM
Thanks! I didn't know the details on the 1111942.
Old 05-12-2026, 07:23 AM
Andre's Avatar
Andre Andre is offline
It may not matter, but those distributor specs were for a fuel type that no longer exists so that may play a part in how you set yours up
Old 05-12-2026, 11:50 AM
Agree. From what I've been reading, it sounds like I just set it up somewhat stock, maybe a little advanced on idle. Then drive it and see what it does and make adjustments as needed.
