Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 06-12-2026, 01:19 PM
DA GOAT DA GOAT is offline
Default Wanted - 1972 intake, iron or aluminum HO
Got my 800 Qjet and now thinking about getting a 72 intake. Just not sure yet if I want to search for one that’s already ported or I port myself. Just kind of seeing what’s out there right now.
Old 06-12-2026, 03:40 PM
The stock intake is cheap and everywhere. I've got multiples. Where do you live?
The Following User Says Thank You to poncho-mike For This Useful Post:
Old 06-13-2026, 08:47 AM
I’m down in gulf shores, AL. I definitely would be looking at a stock iron or an aftermarket aluminum. Don’t need original aluminum as my motor isn’t original. Just going for more stock-ish appearing look
Old 06-13-2026, 11:15 AM
srmmmm's Avatar
srmmmm srmmmm is offline
Be cautious with a new aluminum repop. Before you spend the money for port matching, test the threaded holes for proper fit and perform a pressure test with dye penetrant if you can. I went through two RA-IV reproductions to get a good one. The first was a porous casting that had pinhole leaks in the front runners and crossover, the second suffered from temperature sender holes that were tapped too large in diameter.
Old 06-13-2026, 11:37 AM
That sounds painful. Are there certain companies/castings that are better than others?
Old 06-13-2026, 11:58 AM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
No, they’re all sh*t.
Just get an iron 1972 unit and put it on a diet.
The Following User Says Thank You to 65 Lamnas For This Useful Post:
Old 06-13-2026, 12:46 PM
73ta's Avatar
73ta 73ta is offline
Most all require port matching and welding to get the core shift fixed.
The Following User Says Thank You to 73ta For This Useful Post:
Old 06-13-2026, 04:36 PM
What do yall think of performer rpm?
Old 06-13-2026, 05:00 PM
73ta's Avatar
Good manifold if you can fit it under your hood. I have run one before.
Old 06-14-2026, 01:04 PM
PM sent. Thank you.
