Old 06-25-2026, 03:00 PM
george kujanski's Avatar
Default Needed keys made
Needed keys made for my GTO. Went to True value.. $2.99 each but they didn't work. Turns out the blanks are a bit too long keys don't insert far enuf. In the meantime I went to Ace...$6.99 each.. only the trunk key worked. I did a little file work on the True value ones and they work now. Going to take the Ace one back, for 6.99 apiece!
George
The Following User Says Thank You to george kujanski For This Useful Post:
Old 06-25-2026, 03:02 PM
tempest1964's Avatar
Would it be too much for me to say I miss the old days where products worked and customer service was a given?
1964 Tempest Custom
421 SD clone
KRE 74cc heads
KRE 230°/236° hydraulic roller cam
Rebuilt 3.23 rear end
Old 06-25-2026, 03:06 PM
LastoftheThinkers LastoftheThinkers is offline
I have had the same issue recently. We changed the locks on our house recently and we wanted enough keys made for us, and we had to go through 3 different locations before we got one that actually worked. One would think with "improved" technology it would be more accurate.
I know that I am intelligent because I know that I know nothing -Socrates
Old 06-25-2026, 03:21 PM
ta6point6's Avatar
I just got trunk keys for Trans Am from Ace and they fit fine both of them. The part that surprised me was one trying to find someone who still makes these keys and then the price 5.00 a key. Back in the day it was like 1.50-2.00 per key. Walmart does not do keys anymore and I went to Lowes and he looked up key and said we dont keep that blank anymore. The same story at Home Depot so off to Ace but I guess at Ace at least you get free popcorn, also I was suprised my Ace store no longer carries hand tools
going bandit-Reynolds style
The Following User Says Thank You to ta6point6 For This Useful Post:
Old 06-25-2026, 03:58 PM
Cammer-6 Cammer-6 is offline
I took blanks for a key no one stocked,that I purchased online,and no one would cut them.
I even offered to pay for a blank(that I wouldnt use).The GM dealership was only one that would bother.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 06-25-2026, 04:09 PM
form74's Avatar
form74 form74 is offline
Years ago I took some GM key Blanks I got at a swap to Ace and them make keys for my 74
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Old 06-25-2026, 04:24 PM
Elarson's Avatar
Elarson Elarson is offline
I bought blanks for my '75 Firebird from Ames and took them to a professional locksmith shop to get cut. They all work perfectly.
I've had pretty spotty luck with hardware store keys.
FWIW,
Eric
The Following User Says Thank You to Elarson For This Useful Post:
Old 06-27-2026, 12:00 PM
Singleton Singleton is offline
I used the key codes from my 66 GTO PHS to have new keys made. There are a few places online that do it. Of course if the locks have been changed this wont work
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
Old 06-27-2026, 02:24 PM
dealership required proof of ownership for me to have keys cut to code.
Old 06-27-2026, 06:03 PM
nas t eh nas t eh is offline
FWIW,
Eric
This is what I did too for the 73 Trans Am, three new sets, all three sets are perfect, cheap considering everything else spent on the car. The lock smith I used read the original keys I had, then cut to code.
73 T/A 455, 4speed
Old 06-28-2026, 08:53 PM
Region Warrior's Avatar
Still have old 60s hand held key puncher from work when got new computer in 90s.
Sold old blanks to a guy $5 each.bout 100 blanks.
He probly made alot $ online sales.
Kept 2 sets each uncut for 67 68 FBs even though had 2 pair each original.
Old 06-29-2026, 01:33 PM
Longs's Avatar
Longs Longs is offline
I have the original keys for my '67 GTO but I had a couple of other sets made 40 years ago. I recently was looking into having a new set cut for backup. My extra sets were Cole National, don't use the 67 style hex shaped head (or whatever you'd call it) they were the early 70s rectangular and oval keys.
Old Cole National Keys - Ignition is B48A, Trunk is B49B. See ekeyblanks.com for reference. Says B48A is manufacturer equivalent to Axxess 4 and B49B is equivalent to Axxess 8, which are sometimes found at hardware store kiosks.
Old 06-29-2026, 05:07 PM
Londs.
Think win as most hoarder!
Old 06-29-2026, 05:15 PM
Not disin.
Have mics parts in garage moved here in 85.
Nothing special but need to pass on extra nos soon.
Old 06-29-2026, 08:36 PM
steve v's Avatar
steve v steve v is offline
It can be iffy sometimes trying to make a good copy of a 50+ year key...many are worn smooth or just plain worn out. Your best bet is to find someone (old timer locksmith) with a key clipper as RW mentioned he has.
You can either make it by the key code (many times stamped on the lock casing) or you can measure the key cut depth, you'll get a good crisp key cut that way.
