Showing results 1 to 25 of 248
Search took 0.07 seconds.
Search: Posts Made By: george kujanski
Forum: Pontiac - Street Yesterday, 06:48 PM
Posted By george kujanski
Go ahead and connect bat voltage to the coil ...
It can run for a bit
That's what actually happens during a normal start cycle.
Forum: THE LOBBY 06-25-2026, 03:00 PM
Needed keys made
Needed keys made for my GTO. Went to True value.. $2.99 each but they didn't work. Turns out the blanks are a bit too long keys don't insert far enuf. In the meantime I went to Ace...$6.99 each.....
Forum: Pontiac - Street 05-31-2026, 09:42 AM
When using HEI on a previous points-distributor...
When using HEI on a previous points-distributor car, there should be a wiring mod to provide system voltage to the HEI during crank and run modes. On A bodies, this is as "simple" as using a bypass...
Forum: Pontiac - Street 05-25-2026, 04:59 PM
Regarding the "R" terminal, AFAIK, firebirds used...
Regarding the "R" terminal, AFAIK, firebirds used that terminal for resistance bypass during cranking, A bodies did not use that terminal, at least on a '67.
George
Forum: Pontiac - Street 05-25-2026, 01:49 PM
There you go. The second wire with the large ring...
There you go. The second wire with the large ring terminal goes to the large starter bolt along with the large battery cable. As mentioned above. It's the main power feed to the entire harness.
Forum: Pontiac - Street 05-06-2026, 07:48 PM
yep, I see the ujoint cup halves move relative...
yep, I see the ujoint cup halves move relative to each other.. R&R ujoint.
George
Forum: THE LOBBY 05-01-2026, 01:00 PM
Ran from manifold vac. At high throtlle/ loads,...
Ran from manifold vac. At high throtlle/ loads, manifold vac drops. Driven from gas pumps is more constant.
George
Forum: Suspension TECH 04-26-2026, 10:03 AM
Alignment machines can determine the thrust angle...
Alignment machines can determine the thrust angle of the car, which is the forward thrust vector of the rear axle and generate alignment specs to correct for it. This info is from my time at Sun...
Forum: THE LOBBY 04-01-2026, 07:12 PM
Traveling in the Cammer
The year was 1973. I had a '67 Lemans Sprint, and was stationed at Fort Huachuca,
Az. for AIT. In early January, after the holidays, my wife and I loaded up the
car to drive to Az. from Illinois. ...
Forum: THE LOBBY 03-09-2026, 10:13 PM
Yep, It must be the coolest driveway in the...
Yep, It must be the coolest driveway in the 'hood.
70 degrees today so I painted my aluminum intake, finally!
George
Forum: THE LOBBY 03-09-2026, 02:47 PM
At least the distributor is out in front where...
At least the distributor is out in front where it's easy to get to!
I like it. Throw some quick paint on it. It will look better and provide initiative for more work.
George
Forum: Pontiac - Street 03-07-2026, 10:35 AM
Make sure the belts are the correct width. Too...
Make sure the belts are the correct width. Too narrow and thet ride at the bottom of the groove rather than the sides. They will certainly slip.
George
Forum: THE LOBBY 02-24-2026, 06:53 PM
I also had Kawasaki, it was the 500 2 stroke;...
I also had Kawasaki, it was the 500 2 stroke; scary still. In '76 I was in my first real job at Motorola Automotive.
A few years later I was at Sun Electric. Drove a '67 Lemans Sprint at the time....
Forum: Pontiac - Street 01-30-2026, 02:26 PM
Have you tried using the stethoscope method to...
Have you tried using the stethoscope method to localize the sound?
George
Forum: Pontiac - Street 01-22-2026, 04:10 PM
The service manual states that you should mark...
The service manual states that you should mark the pinion nut relative to the pinion stem and after replacing the seal, tighten the nut so the mark on the nut goes past the stem mark by no more than...
Forum: THE LOBBY 01-21-2026, 07:54 PM
I also still keep my old transistor and I.C....
I also still keep my old transistor and I.C. databooks since I do a side gig reverse engineering old hardware and the data for old devices may not be available online, especially from defunct...
Forum: THE LOBBY 01-21-2026, 07:51 PM
I always buy hardcopy of my music, but I won't...
I always buy hardcopy of my music, but I won't buy vinyl anymore. I hated the clicks and pops of that era and won't go back. The convenience of playing the music is not there either with vinyl. Back...
Forum: THE LOBBY 01-12-2026, 01:45 PM
Looks like his recent medical issues have taken...
Looks like his recent medical issues have taken their toll on him, moving a bit slower, like most of us, I guess.
George
Forum: Pontiac - Race 01-05-2026, 12:10 PM
For manual brakes, a 15/16" or 7/8 would be...
For manual brakes, a 15/16" or 7/8 would be better. 1-1/16" is certainly used for power brake use.
George
Forum: Pontiac - Street 12-31-2025, 11:23 PM
The distributor can be inserted into the block in...
The distributor can be inserted into the block in darn near any position. The caveat is: the #1 plug should be inserted where the rotor is pointing when the engine is on the timing mark at TDC on the...
Forum: THE LOBBY 12-28-2025, 01:31 PM
Bill, you are the man! Best wishes for you and...
Bill, you are the man! Best wishes for you and your wife for the coming year! Happy Hoilidays!
George
Forum: Members Helping Members 12-23-2025, 04:18 PM
There may be a separate battery wire that...
There may be a separate battery wire that maintains the short term memory, like in a car radio. If so, it may be a bad connection there. Just speculating tho.
George
Forum: THE LOBBY 12-01-2025, 10:36 AM
Last year my son bought me a plasma cutter. What...
Last year my son bought me a plasma cutter. What should I ask for this year? HMMMM
George
Forum: THE LOBBY 11-23-2025, 10:03 PM
It's Suprep, or it was years ago. You mix it wit...
It's Suprep, or it was years ago. You mix it wit 8 oz of clear liquid and drink several 8 oz glasses over time. Easy. I used 7 up to mix.
George
Forum: THE LOBBY 11-23-2025, 01:31 PM
Another thing, if you have an opportunity to get ...
Another thing, if you have an opportunity to get CTscan of something see if you can get a widespread scan I had one to check my abdomen, ie. bladder, kidneys, prostate, urethra, etc, Everything...
