Showing results 1 to 25 of 68
Search took 0.04 seconds.
Search: Posts Made By: Tim john
Forum: Suspension TECH 04-21-2024, 01:44 PM
Posted By Tim john
Perhaps reach out to Deaver Spring in California....
Perhaps reach out to Deaver Spring in California. ? send your good original to match it up and or have a new set made to mimic the original. I have their springs and am super pleased. Very high...
Forum: Suspension TECH 07-28-2023, 07:32 PM
Posted By Tim john
I am fond of KONI Red shocks. DSE (Detroit Speed...
I am fond of KONI Red shocks. DSE (Detroit Speed & Engineering) have their own special valved version of them. Check out DSE website for their offerings.
I had KYB Gas-Adjust and thought they were...
Forum: Pontiac - Race 07-26-2023, 01:24 PM
Posted By Tim john
Great find, be fantastic to slip it into a 69...
Great find, be fantastic to slip it into a 69 Trans Am/clone.
Tim john---
Forum: Suspension TECH 07-25-2023, 06:42 PM
Posted By Tim john
Riv-nuts are what I used/installed. Very pleased...
Riv-nuts are what I used/installed. Very pleased and would recommend doing so again. Either plug weld and re-drill or what I recommend above.
Tim john---
Forum: 66-67 GTO Tempest & LeMans TECH 07-05-2023, 12:33 PM
Posted By Tim john
My 67 H.O. four speed GTO came factory w/ red...
My 67 H.O. four speed GTO came factory w/ red liners and the original color was Montego Cream, black interior. Looked very complimentary with the liners, repainted the car white in 1976 and the...
Forum: 68-69 GTO Tempest & LeMans TECH 06-08-2023, 09:22 PM
Posted By Tim john
Regular blue Dawn dish soap helps the new rubber...
Regular blue Dawn dish soap helps the new rubber slide easier as you push, pull and coax the new seals into position. Lube up the new seals generously with the dish soap.
Tim john---
Forum: THE LOBBY 05-17-2023, 09:34 AM
Posted By Tim john
Thank you for sharing this option. Tim...
Tim john---
Forum: 66-67 GTO Tempest & LeMans TECH 05-14-2023, 12:48 PM
Posted By Tim john
Ahh, I was thinking much larger in size. Thank...
Ahh, I was thinking much larger in size. Thank you for posting pictures.
Tim john---
Forum: 61-77 GTO, Tempest & LeMans Parts WANTED 04-23-2023, 07:19 PM
Posted By Tim john
I may have one Jon. I will get up in the loft and...
I may have one Jon. I will get up in the loft and report back.
Tim
Forum: THE LOBBY 04-04-2023, 07:24 AM
Posted By Tim john
Finishing Touch in Illinois, AIH Chrome out of...
Finishing Touch in Illinois, AIH Chrome out of Dubuque, Iowa, D&S Plating out of Holyoke, Mass. These are who I always use. Always pleased, you get what you pay for. Cheap/Affordable does not always...
Forum: The Body Shop TECH 02-12-2023, 11:22 AM
Posted By Tim john
Cerium Oxide is used for polishing glass. I...
Cerium Oxide is used for polishing glass. I purchased it in the past from Eastwood but there are multiple sources available online
Tim john---
Forum: THE LOBBY 01-27-2023, 11:32 AM
Posted By Tim john
As Stuart stated above. I have flown out,...
As Stuart stated above. I have flown out, inspected in person, agreed to purchase and then called my credit union and had them wire transfer the purchase price to their account, took a few hours for...
Forum: THE LOBBY 11-30-2022, 09:24 AM
Posted By Tim john
Same here, I prefer a paper catalog then call in...
Same here, I prefer a paper catalog then call in my orders.
Tim john---
Forum: THE LOBBY 10-18-2022, 06:19 PM
Posted By Tim john
Pontiac engine casting factory video from 1970.
https://youtu.be/9LuXf6gJ-jg
Tim john---
Forum: 67-69 Firebird TECH 10-12-2022, 01:20 PM
Posted By Tim john
*UPDATE* I now have all the retention...
*UPDATE*
I now have all the retention brackets made, they fit the emblem perfectly, the B side of the bumper, holes line up exactly centered, sized correct for the factory size studs and secured...
Forum: THE LOBBY 10-08-2022, 01:17 PM
Posted By Tim john
Radiator Cap Fun (CNC).
A friend and I were messing around with his CNC and we made a radiator cap top/cover. Installs and performs as it should and is kind of nifty.
Tim john---
Forum: THE LOBBY 10-07-2022, 06:56 PM
Posted By Tim john
Vertical Ingersoll Rand, Black Friday after...
Vertical Ingersoll Rand, Black Friday after Thanksgiving special at Farm/Fleet, Tractor Supply is a very good option. They have several sizes available.
Tim john---
Forum: Members Helping Members 10-05-2022, 01:15 PM
Posted By Tim john
Mistakenly leaving the old gasket in place and...
Mistakenly leaving the old gasket in place and installing a fresh filter (w/ new gasket) will also put all the oil on the ground in quick order. Happened to me twice in the past 50+ years. No engine...
Forum: THE LOBBY 09-26-2022, 11:17 AM
Posted By Tim john
Childhood vision to fruition.
Perhaps your vision was similar, mine sure was.
Tim john---
Forum: 67-69 Firebird TECH 09-05-2022, 07:54 PM
Posted By Tim john
All, I have a factory original fastener that I...
All, I have a factory original fastener that I can reference if I decide to go that route for retention, focused on the emblems for now. Super pleased with the results thus far. Really appreciate the...
Forum: 67-69 Firebird TECH 09-03-2022, 05:16 PM
Posted By Tim john
Another journey down state this morning resulted...
Another journey down state this morning resulted in a very satisfying return trip home with precious cargo onboard. I worked on them for several hours this afternoon cleaning them, confirming fit,...
Forum: 61-77 GTO, Tempest & LeMans Parts For SALE 08-31-2022, 01:38 PM
Posted By Tim john
www.cqm-inc.com Skippy, Reach out to the...
www.cqm-inc.com
Skippy, Reach out to the above for custom made bellows (shift boots, clutch fork bellows, brake rod bellows, etc..). They have helped me out in the past with high quality pieces,...
Forum: 67-69 Firebird TECH 08-23-2022, 08:30 AM
Posted By Tim john
Michigan experiences plenty of Sub Zero weather...
Michigan experiences plenty of Sub Zero weather as well. I am in Michigan.
Tj-
Forum: 67-69 Firebird TECH 08-23-2022, 07:37 AM
Posted By Tim john
Backside of bumper, emblem/bumper engagement....
Backside of bumper, emblem/bumper engagement. Note: emblem bosses have been enlarged to fit bumper clearance holes much better than OEM for improved self vertical positioning. The OEM emblem with...
Forum: 67-69 Firebird TECH 08-22-2022, 06:15 PM
Posted By Tim john
*UPDATE* Well folks, Another trip down state...
*UPDATE*
Well folks, Another trip down state last week but oh so worth it.
Today is a monumental day, the emblem is physically complete, the final version that is, and I am delighted to share...
