Forum: 77-81 Firebird & Trans Am TECH
11-28-2023, 09:41 PM
Forum: 70-73 Firebird & TA TECH
11-26-2023, 03:57 AM
Forum: THE LOBBY
11-20-2023, 09:45 AM
11-17-2023, 07:35 PM
It appears you have the original bridge jump...
It appears you have the original bridge jump Bandit.
I'd replace if it were mine. Can be fixed as is but I'd want mine ground back flush and unseen and paint touched up, easier done when not...
11-17-2023, 04:48 PM
11-10-2023, 07:48 PM
Forum: 74-76 Firebird & TA TECH
10-29-2023, 11:49 PM
10-29-2023, 10:49 PM
Forum: General Late Model Tech
10-17-2023, 07:31 PM
10-14-2023, 08:52 AM
Forum: THE LOBBY
10-11-2023, 09:40 AM
09-29-2023, 10:31 AM
75-76 Seat track cover ?
This recently came up another page, trying to identify a mystery plastic piece. With some further searching found these ads on ebay and at FirebirdCentral for used parts. Anyone have these on their...
09-19-2023, 03:50 AM
Another one for rivets, but certainly won't be...
Another one for rivets, but certainly won't be going back that way. I tapped out the bumper, and got low-profile dome bolts with washers to spread the clamping force. Bumper can now be assembled and...
09-18-2023, 10:45 PM
Some simple tests, that don't tell much, is to...
Some simple tests, that don't tell much, is to disconnect the sender wire at the trunk harness. With ignition, the gauge will max out, and without power, should stay there. Plugged back in, when...
Forum: THE LOBBY
09-11-2023, 10:59 AM
Forum: THE LOBBY
09-10-2023, 12:18 AM
09-09-2023, 05:57 AM
Forum: THE LOBBY
09-07-2023, 11:54 PM
genuine Camero mustard cylinder cap
And yes,...
And yes, GM official literature and diagrams refer to the Camero, and other spelling errors.
Also, I think Chinese may read downwards, so pic is Chinese. I...
09-05-2023, 08:52 AM
Some of those studs were threaded into the...
Some of those studs were threaded into the plastic of the box but if you snapped it then along with the nut was probably half eaten away with corrosion at that location. If part remains you could...
08-30-2023, 07:57 AM
Forum: Pontiac - Street
08-25-2023, 11:07 PM
Spot on, there's some very high quality items...
Spot on, there's some very high quality items produced in China. If that's what is required, they will do it. But if the company wants cheap and good enough and to keep it cheap by using unskilled...
08-23-2023, 03:54 AM
08-22-2023, 08:06 PM
08-22-2023, 08:04 PM
08-12-2023, 03:15 AM
