Showing results 1 to 10 of 10
Search took 0.04 seconds.
Search: Posts Made By: Squidward
Forum: Pontiac - Street 07-07-2026, 07:15 AM
Posted By Half-Inch Stud
Black/yellow wire at Wiper motor is switched 12V....
Black/yellow wire at Wiper motor is switched 12V. That will get you started.
After that you ought dig the pink resistance dizzy wire out of the engine-side fuse block, and replace with copper...
Forum: Heating & Cooling TECH 04-06-2026, 01:39 PM
Posted By 73ta
Faster water flow is better according to factory...
Faster water flow is better according to factory engineers. That's why they changed pulley sizes to speedup water pump on AC cars!
Forum: Pontiac - Street 11-18-2025, 02:26 PM
Posted By mysticmissle
car looks awesome great job
Forum: Pontiac - Street 06-30-2025, 08:23 PM
Posted By NateOld687
Starting the dialing in process, she looks better...
Starting the dialing in process, she looks better outside
Forum: Pontiac - Street 06-29-2025, 09:11 AM
I got her running, and drove it for the first...
I got her running, and drove it for the first time! With open headers this thing is loud af..scared me when it first popped, I was scared to drive it knowing it's been years since it's seen the road,...
Forum: THE LOBBY 12-14-2024, 12:28 PM
Posted By camerjeff
Sorry no I went to Central Michigan, and I was...
Sorry no I went to Central Michigan, and I was originally from Saginaw
Forum: Pontiac - Street 12-12-2024, 06:38 PM
Posted By cdrookie
Thanks for the reviews fastekibeast and...
Thanks for the reviews fastekibeast and prostreet64
Forum: Heating & Cooling TECH 11-28-2024, 08:29 PM
Posted By 65 Lamnas
The modern “new” delco temp senders won’t work...
The modern “new” delco temp senders won’t work with ‘68 gauges as you've discovered. Find a 1513371 “nailhead” or 6402383 “spade” if you can. Or else try one from Lectric Limited, as they claim to...
Forum: Pontiac - Boost 01-10-2014, 01:14 AM
Posted By marks73ta
Yes Pontiac used a externally balanced rotating...
Yes Pontiac used a externally balanced rotating assembly. They put some into the flex plate/ flywheel. Whenever I built one of my Pontiacs, I would internally balance it. Then I used zero balance...
Forum: Pontiac - Boost 12-28-2013, 01:00 PM
Posted By Craig Hendrickson
It was a bolt-on kit. It was engineered and sold...
It was a bolt-on kit. It was engineered and sold by H-O Racing Specialties in 1977 and later. See here for details:
http://originalho.com/TFReviveWhat.html
Of course this kit is no longer...
