Old 06-03-2010, 12:23 PM
GOAT490's Avatar
GOAT490 GOAT490 is offline
Thumbs up Iron Dports still Rock!
Originally Posted by GOAT490 View Post
65GTO 3500lbs
497cid 12.9:1 110octane No Power Adder
Factory Block/Crank/D-ports
T400/9.5"4200stall/3.91/30"x9"Radial Slick
Footbrake/6550DA/4900ft Altitude
1.50 60ft
[email protected] 1/8th
[email protected] 1/4
PHILLYGOAT
http://ourworld.cs.com/GOAT490/myhomepage/auto.html
Here are new bests from 2009 PONTIAC HEAVEN:
2900DA
1.41 60ft
6.45@105mph
10.25@127mph
PHILLYGOAT
1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/
3550lbs/ Full Exhaust/ Foot Braking
1.41 60ft [email protected] [email protected](Pontiac Heaven)
More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379
GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4
  #102
Old 06-29-2010, 12:10 AM
XSIVPWR's Avatar
XSIVPWR XSIVPWR is offline
Originally Posted by XSIVPWR View Post
1968 Firebird
474 e-heads victor 1050 Dom
turbo 400
3.89 gear 14x31
3115 w/me in it (not for long)
Best 9.71 @ 138.
Update:
ET & MPH above was when it was white & VP C-12.
After glass and suspention & E-85
9.40 @ 147.00
  #103
Old 08-09-2010, 05:46 PM
MrPushrod's Avatar
MrPushrod MrPushrod is offline
Update:
9.40 @ 147.00
Lookin good Gary. Didn't see it at HAN though.......
  #104
Old 10-19-2010, 01:06 PM
firecloud firecloud is offline
Friday night they had the last "midnight madness" race at gateway and went. Only got 2 passes in, but I have a new best E.T. ! Last week I took the car to my engine builder, and we worked on the rear suspension trying to get it to stop wheel hopping. It worked! I ran a 10.78 at 131 mph, with a new best 1.56 60' ! For my car thats a huge improvement! Second pass I messed up and nearly stalled it on the line, so I didn't even push it that pass and went home. (plus I couldn't keep my eyes open! Too late for me) Big thanks to my engine guy!
  #105
Old 10-28-2010, 06:49 PM
Torment's Avatar
Torment Torment is offline
67 Firebird 33x18.5 DOT's, mufflers, 526CI, roots, carbs, E85
1.26 60 ft, 8.60 @ 156.3mph at 3550lbs -Chris
Name:	002 - Copy (2)_1.jpg
The secret to happiness is not getting what you want but rather, wanting what you have.
  #106
Old 11-05-2010, 04:05 AM
Ballast's Avatar
Ballast Ballast is offline
64 GTO.
461 CI. T400 Rev Man. 3.7 9inch
Holley UHP950. MSD 6AL, coil, MSD dizzy locked at 36deg
comp cam XR288HR with solid roller lifters
87cc E heads cleaned up and opened up intake wise.
T2, Dougs 1 7/8inch into 3inch system with violators.
255 R60X15 radials.
Full street tyres and suspension.
1.8 60ft, 11.87 @ 116.5mph at 5800rpm.
Steve
  #107
Old 12-22-2010, 06:16 AM
trdbrd's Avatar
trdbrd trdbrd is offline
67 400 Firebird 3780 with driver, all steel except hood, full interior with heater, 1200watt RMS 6 speaker stereo.
467 10:25.1
Solid Roller bumpy thing
Victor/8896 Dom
Kauffman D port
1 7/8 headers 3.5" exhaust to the axle
TH350/4400 converter
3.70 gear
275/60/15 MT DR
N/A
60' 1.48 10.61 @ 127.3 Bremerton Raceway
84/72 950psi/5psi .2 sec delay
60' 1.42 1/8 6.1 115mph 1/4 9.54 @ 141.6 Pacific Raceway
in need of taller gear for bottle runs
  #108
Old 01-02-2011, 09:11 PM
XSIVPWR's Avatar
I was there but not the car. This is what it looks like now.
  #109
Old 01-02-2011, 09:36 PM
mysticmissle's Avatar
wow love new color!
  #110
Old 06-22-2011, 02:25 PM
Ron Genovese's Avatar
Ron Genovese Ron Genovese is offline
66 GTO tube chassis 2900# Fastest run with non wide port E heads.
1.26 60 foot
145 MPH
9.13 ET
66 GTO
  #111
Old 07-09-2011, 08:24 PM
KARGUY KARGUY is offline
1965 GTO
3650 Lbs w/driver
461 (400 stroker) 2 bolt mains w/stock bolts
310 cfm CNC by KRE Aluminum d-ports -9.9 compression
Torker 2 w/750 Holley DP
1 inch Wilson tapered spacer
Comp cams 242/248 XE Solid roller
1 3/4 x 3" dougs headers w/3" x pipe
T-400 w/10" 3600 Conti
3.73 12 bolt
275/60 MT Drag radials
10.94 ET
121.85 MPH
1.53 60 ft
KARGUY
  #112
Old 11-20-2011, 10:08 PM
repoman8x66's Avatar
repoman8x66 repoman8x66 is offline
Default flying
just got out for the first time this year and i'm running great first pass off the trailer 8.97 154.9 mph 5.68 121 mph
  #113
Old 11-20-2011, 10:09 PM
cant wait till 2012 making a few changes hope to hit some 8.80s
  #114
Old 12-18-2011, 05:33 PM
LenCaverly LenCaverly is offline
Default 77 TA
10.12 135.39
77 TA 3500 lbs 315 50 15 MT drag radials ,455 11.4/1 1195 dom HP heads solid roller 4.10 gear ladder bars 1.457 60ft 6.5 1/8 10.12 135.39 1/4
need traction
Len
  #115
Old 03-05-2012, 10:55 PM
PPM505's Avatar
PPM505 PPM505 is offline
1969 fire bird,505,full interior,all steel 3660lbs 8.96@153mph on 250 shot and 295 drag radials with e-heads 320cfm. 5.65 in the 1/8
  #116
Old 03-05-2012, 11:01 PM
PPM505's Avatar
1989 mustang,505 with cv1 out of the box,3200lbs single fogger best to date 5.17@1/[email protected] and 8.24@167 in 1/4, on 295 drag radials
  #117
Old 05-20-2012, 10:09 AM
i'm running 8.80s with a 2870lb car, not bad with a 1972 block 1 carb and no help
  #118
Old 05-20-2012, 10:12 AM
Old 07-11-2012, 01:52 PM
Wareagle's Avatar
Wareagle Wareagle is offline
Smile
Yes - that is Awesome - great job .
  #120
Old 08-12-2012, 08:47 AM
Chupa's Avatar
Chupa Chupa is offline
Just had a new best - 1.40 60' - 6.65 @ 100.7 - 3300' DA
1968 F-bird
3300 lbs - stock suspension , 29 X 11 Tires
455 Pontiac - 310 eHeads - 270@050 cam/660 lift, 11:1 comp.
TH400 - 8" ATI MRT Treemaster (5200 stall)
12 bolt - 4.30 gears
I swear by this converter... with pretty much just a converter change I went from 7.0's to 6.65.
