Old 01-10-2012, 11:44 PM
john marcella john marcella is offline
Originally Posted by quick67bird View Post
If we would like one of these manifolds how do we go about ordering one from you John?
Call me. Marcella Manifolds 248-259-6696
Ill see if i have pics of the 2 into 1 as well. Buts its #16 to #20.
4 into 1 are in stock and i have one 2 into 1
$135 & $145 i can add a radiator cap as well +50
Old 01-11-2012, 01:59 AM
huddie huddie is offline
So,do you tap and plug the water pump housing?Thanks for the pic's.
Old 01-11-2012, 02:18 AM
quick67bird's Avatar
quick67bird quick67bird is offline
Yeah. From what I understand a lot of people do not use the bypass anyways. A lot of racers either just use a restrictor or drill holes in the thermostat.
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
Old 01-11-2012, 11:12 AM
60man's Avatar
60man 60man is offline
Sent you a PM John...
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 01-12-2012, 01:38 PM
grandville455's Avatar
How would this work For My KRE Heads? Would U run a line to each in back ,and also to the two front one's too? Also street driven, So U plug the hole that normally goes to the cross over on the timing cover, and the nipple on the side of the timing cover too?
Darby
M/T 275/60 ET SS Drag Radial
Old 02-06-2012, 05:04 PM
60man's Avatar
Got my water maniflod today. Very nice quality !!!
Thank you John..
Troy
ECM member.
MANDRA
Old 02-06-2012, 07:20 PM
russosborne's Avatar
russosborne russosborne is offline
Are these only for aluminum heads, or could they be used on factory iron heads as well?
Thanks,
Russ
Old 02-21-2012, 04:19 PM
If you get time could you post a pic of the two into one?Thanks,Lance
Old 02-28-2013, 11:23 PM
lugnutt's Avatar
lugnutt lugnutt is offline
Send a message via MSN to lugnutt
Default Manifold
I ordered one of these today (finally!). Just thought I'd bump this back up for John!
If its one thing I know, its..... Uhhh I forgot .
What do you mean I couldnt be the president of the United States of America, Its still WE THE PEOPLE, RIGHT!!
Old 03-01-2013, 07:04 PM
jm455ho's Avatar
jm455ho jm455ho is offline
Got mine several weeks ago. Very nice piece.
www.hobracing.com
Old 03-03-2013, 01:39 PM
jm455ho's Avatar
[QUOTE=john marcella;4515616]This is one of my 4 into 1 water manifolds. It's set up for 4 #10 o-ring fittings (but you can use a combination fitting that is up to #12) and 1 #20 o-ring on the opposing side.
I also make a 2 into 1 water manifold. It uses 2 #16 to 1 #20.
Both have provisions for NPT for water temp pick up.
Anyone with a brand and part number for the #20 fitting?
John
www.hobracing.com
Old 03-03-2013, 09:57 PM
60man's Avatar
[QUOTE=jm455ho;4868284]
John
Got mine from Jegs....don't have part # handy..I just looked under 20 AN in search window
ECM member.
MANDRA
Old 03-03-2013, 10:57 PM
John
Jerry Bickel race cars or Rick Jones race cars has them, good price to.
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
Old 03-04-2013, 06:40 PM
beastmaster's Avatar
beastmaster beastmaster is offline
This is my set up, its old-before the 2pcs billet design. I am picking up water between the middle exhaust ports.The water temp is in the middle of the water manifold.
John do have anything for the 3rd Gen Bird body style which the radiator sits lower than the top of the block.
84 T/A
w/ IA 2 -- 505 N/A
w/ Tiger heads / BOP intake. "Best time" [email protected]/1.28 60ft.
77 Firebird formula 463 w TRW dome
pistons w/ 4x's /edelbrock performer
http://www.youtube.com/watch?v=KK163BxD9EY
Old 07-25-2013, 11:19 PM
R 70 Judge's Avatar
John are you bringing any of these with you to Norwalk?
James
1970 Trans Am
Old 07-26-2013, 12:06 AM
I will bring a few. Price has gone up though. 160$ My cost went way up on having them cut.
John Marcella
[email protected]
ph. 248-259-6696
Old 07-26-2013, 12:56 AM
R 70 Judge's Avatar
Thanks John. Still worth it for such a nice piece. Please save one for me if you can. Jim Robertson said he will stop by to pick it up for my build. If you still have any of the older style ones with the "M" on them that would be fine too. They are both works of art
James
1970 Trans Am
  #38
Old 07-26-2013, 01:00 AM
67cruiser 67cruiser is offline
John, may i ask, its such a long run all the way around motor and back to your home connector,wouldn,t been better just to go under the intake??
Saving my pennys, i got to have one of these, I love the looks!! Opps thought lines went around backside of motor, my mistake!! Senoir citizen momment!!
  #39
Old 07-26-2013, 03:47 AM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Nice work!
  #40
Old 07-27-2013, 04:26 PM
Robert Williams's Avatar
Robert Williams Robert Williams is offline
Default #20 o ring fitting to 1-1/2 rad hose...
got mine from jegs made by Meziere part number WN0032S this number is for a black fitting and they have other colors also.
"Three may keep a secret, if two are dead"
~ Benjamin Franklin ~
