Old 03-29-2007, 01:31 PM
rompn63's Avatar
rompn63 rompn63 is offline
Default Running slicks without tubes
I want to try running my new Mickey Thompson 10.5 W slicks without tubes but the last time I did it the tires would go flat in a few days. I heard that using soap inside the tires would eliminate the problem. Do any of you have any tips or tricks that work?
Old 03-29-2007, 01:47 PM
Elarson's Avatar
Elarson Elarson is offline
Check the thickness of the tire bead and your wheel rim carefully. If you use lightweight wheels, the standard rim screws can break thru the tire bead and they'll go flat. We had to buy screws that were slightly shorter.
Old 03-29-2007, 02:01 PM
lakefect lakefect is offline
buy a bottle of palmolive dish soap coat the entire inside of slick,let dry for a couple hours and your done.mine have set all winter no loss of air.dave
Old 03-29-2007, 02:08 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
A wrinkle wall tire requires a tube due to the flexing of the sidewall which in turn can break the bead of the tire from the rim causing bad things to happen.
I did it 12 years ago when I borrowed a friends M&H tires. I didn't know there were no tubes. I lived but wouldn't intentionally do it.
Most likely you'll be okay if your car doesn't launch hard but why take the risk...
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
Old 03-29-2007, 02:38 PM
screamingchief's Avatar
Ha ha ha,,,that's a hoot,,,you obviously dont know who rompn63 is!!!
Joe's car launches harder than most I've seen,,,but he'll be just fine if he listens to the first two replys.
Know of too many extremely fast/hard launching cars that are'nt using tubes to listen to the "chicken little/sky is falling" types trying to advise against it.
Liquid dish soap works,many prefer palmolive,but other brands have been known to work too,seems one of those deals where susperstitious types have their own favorites,some guys prefer Dawn or some other brand over the palmolive.
There have been other threads here on this subject,I'll see if I can dig them up and provide some linkage for ya'll.
This space for rent...
Old 03-29-2007, 02:59 PM
Johnny406's Avatar
Old 03-29-2007, 03:03 PM
fasteddy's Avatar
fasteddy fasteddy is offline
Agree with the "Chief" here. I ran my M/T 10.5Ws without tubes for 2 seasons -chords were showin-never flat. I prefer the lemon scented dish soap fellas. LOL
fasteddy
Old 03-29-2007, 03:06 PM
1.22 SIXTY is that launching hard?
Old 03-29-2007, 03:09 PM
Johnny406's Avatar
When I buy new slicks next year I'll rethink my position... I currently run M&H Racemasters...
Old 03-29-2007, 03:15 PM
R 70 Judge's Avatar
Palmolive dishwashing liquid...Softens hands while you do dishes! You're soaking in it!
http://www.tvparty.com/g2c/madge00.ram
But seriously... When I changed to my new wheels the valve stem hole wasn't big enough for my tubes to fit through. I had the tires installed anyway, but wasn't sure if it would be safe to run them without the tubes. Hmmm, I guess I can. (M/T ET Street 28x12.5 on M/T ET Drag wheels)
James
1970 Trans Am
Old 03-29-2007, 03:43 PM
Just an FYI for those that dont know who rompn63 is:
Joe's "rompin redskin" is a NSS car that runs in the low tens regularly IIRC,and the launches are indeed impressive!
His best is a 9.75 @ 138 in "match race" trim.
Nostalgia super stock.com
I gotta go find those other threads...
Old 03-29-2007, 04:15 PM
Here ya'll go,some food for thought:
http://forums.maxperformanceinc.com/...d.php?t=459849
http://forums.maxperformanceinc.com/...d.php?t=403840
http://forums.maxperformanceinc.com/...d.php?t=397130
http://forums.maxperformanceinc.com/...d.php?t=436947
HTH.
Old 03-29-2007, 04:57 PM
White Warrior White Warrior is offline
I have had my best luck having the tires mounted and inflated while the dishwashing soap is still wet.
Old 03-29-2007, 05:20 PM
J Brady's Avatar
J Brady J Brady is offline
Dawn dish soap, no screws, and no tubes, 1.07 sixty ft's. never a problem!
Old 03-29-2007, 05:25 PM
rompn63's Avatar
Thanks for all the replies, no tubes for me.
Old 03-29-2007, 05:35 PM
Johnny406's Avatar
I'm getting smart...er from this post. I run steel wheels with 28-105.15 M&H Rasemaster Cheater Slicks. I do use tubes. Does a tire bond better to a steel wheel or aluminum wheel. I'm guessing an aluminum. Should one wheel material over the other use screws? Does weight (in my case 3730lbs) make a difference on a 12 second car on weather to screw or not?
Old 03-29-2007, 05:41 PM
MrPushrod's Avatar
MrPushrod MrPushrod is offline
If the hole is too small get a drill.
Don't run them without tubes.
Old 03-29-2007, 06:13 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
I've run without tubes for 3 years. Screws, no tubes, and Palmolive...no troubles, no leaky.
I'd not worry about rim screws on a 12 second car. If you are worried, make marks on the tire and the rim, and see if it's moving. I did that for a long time when I was slower. Once the tires started moving about an inch per pass, I decided to screw them.
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 03-29-2007, 06:19 PM
MrPushrod's Avatar
http://www.mickeythompsontires.com/tech.php?bulletin=s6
Old 03-29-2007, 07:25 PM
Brad B. Hillebrand's Avatar
Brad B. Hillebrand Brad B. Hillebrand is offline
I have no idea why anyone would take a risk and run tires w/o the tubes. To me it's a risk not worth taking. So, $50 bucks for a tube, well worth it....
