#601
Old 07-26-2014, 10:52 PM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
Ah-Ha, I niticed a 2000 "C5" in the background ... thats where the C5farmer comes from?
Car is really looking great! What transmission and shifter are you using? John
Originally Posted by c5farmer View Post
We have the Lemans running and ready for its new red top. Monday is the appointment for the top installation. The engine started but ran hot and woulddn't idle. Problem was the timing not having enough advance. Once I got it to 10 degrees BTDC, it ran like a champ. The convertible top bows moved slow until the pump was bled and filled per the 63 Body Shop Manual. It has been 3 years of body work, paint, engine overhaul, and assembly, but it is finally getting close to being finished. The Fat Mat insulation, interior, and exhaust system are left to do. Should be able to take it this summer for the first drive since 1990.
  #602
Old 07-27-2014, 08:37 AM
c5farmer's Avatar
c5farmer c5farmer is offline
Default c5
John
Yes, the c5farmer tag comes from having a 1998 C5 corvette and growing up/working in agriculture. The convertible has the stock transaxle and uses the original automatic console shifter. Thanks for the nice comment about the car.
  #603
Old 08-09-2014, 09:31 AM
Paul Yeaman Paul Yeaman is offline
Default Susan's car
Hi Jerry,
Are you warm yet? I'll bring an extra coat the next time I go to a show where you may show up!
It is always great seeing you and Susan - ' like a reunion.
This car looks great!!! 'Can't wait to see and hear it.
'Be sure to let me know when the two of you are going to be here to pick-up your newest gizmo.
'Til then . . . Paul
  #604
Old 08-19-2014, 12:00 AM
BioJester BioJester is offline
Originally Posted by '62pest View Post
i finally got to a computer where i can see what i am doing instead of using my phone. so after the long awaited unveiling here is my '62 tempest that i have been working on restoring with a touch of my own personal taste. i still have a lot of putting back together to do as well as blacking out wheelwells and the front grill area and interior is the next big expense.
What rim and tires are you running?
  #605
Old 08-19-2014, 04:49 PM
Radman's Avatar
Radman Radman is offline
Very nice. Will we see it at a Little Indian Pow Wow next year?
  #606
Old 08-31-2014, 02:21 AM
Sanduners's Avatar
Sanduners Sanduners is offline
Default Frost King did a great job
In looking for a good product to insulate the floor I read on a forum to use Frost King duct insulation. The pros and cons of this product made me try it. Since the car had nothing under the carpet before (except what was left from 1963) I should notice a more quiet ride. But being a convertible who knows.
I used 2 packages (15' rolls) of Frost King, one package of their pipe wrap tape and half a roll of 3M metal repair tape. All together my cost was under $60 in materials.
I think it came out great!
ID:	374828   Click image for larger version
  #607
Old 08-31-2014, 11:39 AM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Originally Posted by Sanduners View Post
...... All together my cost was under $60 in materials.
Looks nice!!
Jim
  #608
Old 08-31-2014, 11:48 AM
c5farmer's Avatar
Default insulation
Looks good and the cost is about half of what I spent putting "Fat Mat" on my car's floor and doors. Thanks for the cost saving tip.
ID:	374844   Click image for larger version
  #609
Old 09-02-2014, 09:23 PM
blueghoast's Avatar
All right then and now for the important question.
Where do you get this stuff from. Thanks. LOL
GT.
  #610
Old 09-03-2014, 12:15 AM
Sanduners's Avatar
GT.
Purchased all at Lowes.
  #611
Old 09-03-2014, 10:42 AM
Here's a picture of my '63 Tempest race car with the blower conversion complete. It's been fired, just waiting for cooler weather to take it down the track. The conversion is documented here:
http://forums.maxperformanceinc.com/...d.php?t=711959
Jim
Name:	rc etc 4-14 032.JPG
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
  #612
Old 09-03-2014, 11:57 AM
63Banshee's Avatar
63Banshee 63Banshee is offline
I'm dig'n the blower!
  #613
Old 09-03-2014, 11:50 PM
Sanduners's Avatar
Now that looks WICKED !!!!
  #614
Old 09-09-2014, 11:20 PM
Rick Beller Rick Beller is offline
Default What projects are you working on
New rebuild on my 194.5 cam, head,intake carb and everything.[ATTACH][/ATTACH]
  #615
Old 09-20-2014, 04:09 PM
63lemanster's Avatar
63lemanster 63lemanster is offline
Jim
awesome! can't wait to see it rip! thinking about going blower on mine.
  #616
Old 09-22-2014, 11:35 PM
DeeRock Lemans DeeRock Lemans is offline
Dragstar, do you still have that 4 barrel?
  #617
Old 09-23-2014, 03:07 AM
Drag Star Le Mans's Avatar
The carb and/or the intake? I am keeping that engine together, have a few single plane intakes around.
DragStarLeMans
  #618
Old 09-24-2014, 03:18 PM
Just the carb, already have a freshly painted manifold. I actually have 2 4bbl's, one that I'm rebuilding and will use on my '62 Tempest automatic and another just for spare parts, some of which are missing. But the one I'm putting on came off a manual-shift Tempest and the other is like the one you got, for the automatic with that vacuum fitting between the 2 mixture screws and I'm switching the base from the spare carb onto the other's air horn that I'll be using and because it's missing the vacuum fitting and it's just got the hole there, I made a vacuum fitting with some brass parts and run a hose from that to the hardline...there was a 1bbl in it before that I pulled out to 4bbl it. But didn't know if you wanted to get rid of your carb or not and it looks complete, so just figured I'd ask. Do you have any spare parts for it, such as the throttle spring bracket (or at least have a pic of it so I can make one) that mounts onto the carb base and do you have a close up shot of the side where the linkage is at?
From what the shop manual shows, the kickdown linkage for this carb is different from the one for the 1bbl and wanted to see what yours looks like to see if I can make one or even use the same 1 bbl linkage and the kind of stud it uses, since my carb doesn't have that. This would really help. Have asked this around PY forums, but so far, no answers. Thanks
  #619
Old 09-24-2014, 06:47 PM
c5farmer's Avatar
Default 3 years of work
We have been restoring this Lemans for 3 years and I have been posting the progress over the years. It has required many hours and dollars, but the car is finally looking like a car again! The "Fat Mat" insulation is done on the floor and the trunk mat is installed. The carpet and interior is next, followed by the exhaust system. I ordered an OEM replacement dual exhaust system from Classic Car Exhaust Ssytems in Ohio. It will be the last installment before driving the car. All the work, except the body and paint, was done in our garage. The car is a 326 (now 350) automatic with Power steering and power brakes.
ID:	377157   Click image for larger version
ID:	377158   Click image for larger version
ID:	377159   Click image for larger version
ID:	377160   Click image for larger version
  #620
Old 09-24-2014, 10:06 PM
It's looking Incredible Jerry
