Old 11-05-2024, 02:59 PM
BigB's Avatar
BigB BigB is offline
Default Struggling with 1975 Firebird power steering and alternator configuration
I am restoring a 1975 Firebird Formula and unfortunately didn't remove the accessories myself. I also have multiple brackets. This is an A/C car that I believe has the 80amp alternator. I know the brackets on the power steering pump are the original, but cannot find any good pictures online, or diagrams to show which brackets to use and how everything mounts. I'm hoping someone here can assist with info and maybe take a quick picture or two of their setups for me if they are also using this power steering setup. Thanks in advance -B
ID:	642401   Click image for larger version
ID:	642402   Click image for larger version
ID:	642403   Click image for larger version
ID:	642404   Click image for larger version
Old 11-05-2024, 04:46 PM
400 Lemans's Avatar
A little hard to see but hit the zoom in button.https://www.chicagomusclecarparts.co...s/1975firebird
The Following User Says Thank You to 400 Lemans For This Useful Post:
Old 11-05-2024, 06:49 PM
Held for Ransom's Avatar
Alternator/bracket is not an 80 amp set up.
https://forums.maxperformanceinc.com...d.php?t=399948
1975 should be like the '71...
https://forums.maxperformanceinc.com...d.php?t=383724
So long, farewell.
Old 11-05-2024, 07:18 PM
Formulas's Avatar
Formulas Formulas is offline
last time i saw an 80 amp in person in my driveway was 30 years ago so i was hesitant to post i didnt think he has an 80 set up... the 80 that i had the alt was non adjustable used the small idle pulley to tension belt
Old 11-06-2024, 03:59 PM
mgarblik mgarblik is offline
I am going to attach some pics of a 1973 Firebird accessory layout. I do not know for sure if this is the same as a 1975. This is a non-AC car, but PS and ALT may be the same? Not an 80 amp Alt. Hope this helps.
ID:	642439   Click image for larger version
ID:	642440   Click image for larger version
ID:	642441   Click image for larger version
Old 11-06-2024, 05:10 PM
That look similar to my 74 setup with A/C and 80amp...unfortunately she is in storage or I could get a snap
Old 11-06-2024, 07:01 PM
Looks like my 78 setup .
Old 11-06-2024, 08:18 PM
Big Bear's Avatar
Big Bear Big Bear is offline
Was collecting pictures to reference when assembling my 74. This is probably the most clear.
The Following User Says Thank You to Big Bear For This Useful Post:
Old 11-06-2024, 09:54 PM
BigB's Avatar
This is very helpful, thank you.
BigB's Avatar
Thank you, very helpful.
Old 11-06-2024, 09:55 PM
BigB's Avatar
Old 11-06-2024, 10:11 PM
BigB's Avatar
So I was missing the correct bracket that goes on the water pump. I just ordered it on Ebay. Thank you all for your help. Hopefully when it arrives, I can get this thing bolted up and then fired up. This is a father, daughter, and grandfather project with my 13yr old daughter. We are very close to sending off for finishing body work and paint.
ID:	642465   Click image for larger version
Old 11-07-2024, 08:14 AM
Skidmark's Avatar
Skidmark Skidmark is offline
So it's a keeper. Good deal. Hope you post some after pics.
72 Lemans sport 462 auto
75 Trans Am 4 speed 39k miles
The Following User Says Thank You to Skidmark For This Useful Post:
Old 11-07-2024, 08:59 AM
Formulas's Avatar
So further 80 amp discussion... the 80 alt housing is unique isnt it slightly bigger than others in the day?
Old 11-07-2024, 10:45 AM
george kujanski's Avatar
12SI alt, yes bigger than a 10SI, which was probably the norm in those years.
George
Old 11-07-2024, 03:01 PM
gonna b nice....good luck
Old 11-07-2024, 06:26 PM
AG's Avatar
AG AG is offline
I have an 80A alternator and it is 6.5" in diameter.
