this might be a stupid question, but im asking anyways. Wont all that exhaust pipe around the radiator be bad? keep temps a little higher?
463 Stroker Kit. ross pistons. h beam rods. eagle crank. 62 heads 72cc, port matched Performer RPM-850DP Auburn- 3.55 gear CC HR custom grind |
My car ran in the 9's with mild steel headers that didnt trap nearly the amount of heat these will. I think that was a good question. Onmy car I will be adding a chin spiler of some type to both help retain heat and to stabilize the car at higher speeds. alot of air can get under a car at 145 MPH.LOL
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
At this point they have not been tested on second gens yet. They will be in the future but we have been concentrating on the 67 thru 69 platform simply because that is what I had available to me.
When are you going to the Valley again ?
Count me in as another one interested in 2nd gen setups
Panos Little Miss G Racing on Youtube |
I have got to get it back together first. I was hoping it would be back together and done by now to be honest but I have another kid on the way, Im building a 17,000 Sq ft building for a company in Bristol, building a convertible 69 bird, and just of ton of other things trying to keep me from racing.LOL Have you seen the car go at the valley? It looks like 12 second car at best before you see it go doesnt it? I bought Gen 7 DFI for it and am trying to decide if I am gonna spend all the money right now to run it or go back carb'd for awhile. I have really been concentratng on getting these headers done and getting going with them before the building was in full swing. I told alot of people I was going to do this and When I say I am going to get something done I do my best to get it done. I cant wait to run something again. I was just out riding my CR500 cause I am selling it, and I miss the power!
Where in mass are you?
Anywhere near simsbury? Id like to take good look at your second gen if your not to far away
Hmmm...I bet that would fit nicely in my '73 Ventura since it uses the same subframe as a first gen bird.
All of my cars are Hybrids...they burn gas and rubber! '73 Ventura, Spotts 462 roller 10.785 @ 122.79, 1.507 60 ft 2850 lbs. plus driver, 3150 race weight '69 Firebird Convertible, Spotts 455 with long branches 12.561 @ 107.62, best on old 455 4290 race weight '72 Formula 455 HO numbers matching auto, work in progress! |
I will be looking forward to the 2nd gen build of these too. Keep up the good work.
Wanted: Victor 4500 Intake, Holley Dominator Carb |
. Married life makes it almost impossible for me to take car related trips that long However, if you are planning to venture up this way at all, let me know, and I'll be glad to hook up with you.I'd like to help you out if at all possible... It is one of my long term projects to turbocharge my T/A, and whip the azz of my 9 second turbo DSM
tough for me to get out too got alot going on right now.
You never know though.
Just give me a couple of weeks heads up, and we'll work something out.
I will PM you
My buddy has a 2nd gen local to me with the engine out so I am going to stop by this week with the headers and drop them in the engine bay. see if its a definate NO FIT situation or not.
if it looks good we may bolt a block and heads in soon and see how they work out. If the first gen headers sell OK I will definately be doing a 2nd gen set up one way or another.
should fit very nicely!
heres a link on a car running basically my same set up. (one of my turbo's)running the same ETS etc. Proving how well this combo works!
http://www.pontiaczone.com/forum/sho...t=24485&page=3
#38
Any word if these fit a 2nd gen (mines an 80).
Thanks |
#39
You guys can count on Jeff.. He'll set you up with good stuff!!
