Old 12-21-2013, 10:15 PM
john31s john31s is offline
Default AGR Steering Box Quetion
Anyone running a AGR steering box in their car? I'm thinking of running one of these:
http://www.summitracing.com/parts/ag...c/model/lemans
I was also wondering if I could retain my original PS pump.
Any input/help would be greatly appreciated
-John
1970 Lemans 350/ TH350 ProTouring Madness
Old 12-31-2013, 07:41 PM
I am on my second in my truck. Quality control not good it needs replacing now.
Old 01-02-2014, 07:26 AM
Nicks67GTO Nicks67GTO is offline
Ever consider the el-cheapo Jeep Grand Cherokee box swap? It's a 12.7 steering with the correct stops and its bolt in for under $100 bucks. Ive got it on my 67' GTO and its awesome.
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies
- Build Thread
http://forums.maxperformanceinc.com/...615847&page=23
Old 01-02-2014, 10:10 AM
My experience too, the first one was over-assisting on the clone, right at the top, car was all over the road. Then it started to leak out the top plate when I steered right.
The second one is on there now, doesn't leak, but still has an uncomfortable feel at the top, wanders some.
I will probably send the one to a rebuilder, there's several out there that do good work. I suggest that over pulling a boneyard box, can get any ratio you want and no modifications needed.
I have an AGR in the driver, got it years ago, never had a problem with it. Go figure.
Old 01-02-2014, 10:18 AM
rohrt rohrt is offline
I bought an AGR pump and they changed my torsion bar in my box after I had Lee do the 12:1 gears. The steering was too light for my taste.
You may be money ahead to just send your factory box out. At least you know it will be correct for your car and also have the correct stops too. I know both Lee and AGR can do those rebuilds and be sure to specify the torsion bar you want.
Old 01-04-2014, 07:24 PM
fiesta62's Avatar
fiesta62 fiesta62 is offline
-John
hi, i went thru hell with agr.....3 steering boxes....1 box locked up, 2nd box almost melted it got that hot the paint on my pump rubbed off, the oil passage little brass insert inside box was blocked and needed to be replaced, 3rd box would not give me full lock on left turns, agr kept trying to put blame on me and my install but my mechanic took a video of the install and the box hooked up being tested we proved the boxes were faulty, you have to be careful stops in the A body box were different to stops for the later B body cars , ames told me themselves that there re-builder said the boxes look identical box stops inside are different, i made it very clear to agr i want full lock either side but they still got it wrong, also had trouble with rock auto boxes, in the end my mechanic changed stop in box to give full lock, and also install a new brass insert into the box to allow fluid to pass thru....bottom line if you buying a box dont use agr or rock auto, i hear lee enginering are good but never used them...i had almost 5 months of hell with boxes with these guys a lot more trouble than i can mention here, be carefull, .good luck,
Old 12-30-2014, 12:19 PM
SteveGB21's Avatar
SteveGB21 SteveGB21 is offline
Send a message via Yahoo to SteveGB21
Default On the AGR power steering box & pump.
I ran a setup in my 70 LeMans. It leaked like a BP oil derrick. Decided to go back to a stock setup with the 3 turn to turn ratio (NAPA has them, but you will need a core). Same with the power steering.
Old 12-30-2014, 01:58 PM
pugslyx234 pugslyx234 is offline
Cherokee grand easy and its a saginaw box.
Old 12-30-2014, 02:30 PM
Verdoro 68's Avatar
Grand Cherokee box is the way to go. All you need are inserts for the Cherokee box so you can use your stock lines and a new rag joint. One of the best bangs for the buck I've done.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around)
Old 01-02-2015, 01:51 PM
SMW SMW is offline
I just picked up a Jeep Grand Cherokee box from Pick-n-Pull for $42, $36 plus $6 core charge. The hose adapter kit from Lee is $20. Better hurry Mr. Lee told me he is retiring and trying to sell the business.
Old 01-12-2015, 11:14 PM
jotrout jotrout is offline
Do you have contacts for Mr. Lee please.
Joe
Old 01-13-2015, 04:38 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Default Lee's
http://lee-powersteering.com/
I did this conversion on my 70 lemans, was great, had to go manual steering now with the turbocharger. Still saving that set up, you never know.
Old 01-20-2015, 07:06 AM
topless lemans topless lemans is offline
what year of steering box would work out of the Grand Cherokee to fit a 67
Old 01-20-2015, 10:03 AM
71 T/A 71 T/A is offline
For my 69 GTO, I bought a faster ratio (2.5) box from Year One and it's been great.
Old 01-20-2015, 11:56 AM
Which one? The one with IROC internals, QF97? Or one of the AGR boxes?
Old 01-20-2015, 02:12 PM
David Jones's Avatar
Send your original box to Chip at http://www.powersteering.com/
Tell him what you want it to do...........
Old 01-20-2015, 02:24 PM
Just a modified stock ps box for GTOs, could have been IROC, but it definitely wasn't AGR.
Old 01-26-2015, 02:59 PM
berrygoat's Avatar
berrygoat berrygoat is offline
x2 !!!!!
Old 02-03-2015, 11:57 AM
1966socalgoat 1966socalgoat is offline
Go to PSC in Texas, great stuff http://www.pscmotorsports.com/
Old 02-24-2015, 04:15 PM
Nickv's Avatar
Nickv Nickv is offline
Yup. get yourself one of these. I put one in my 72 Lemans, night and day difference. They make fittings so that you can use your existing SAE hoses. Bolts right in, I believe I uses a rag joint for a 1980 Camaro to get to bolt up to the existing steering wheel shaft. I wouldn't pay $400 for no steering box unless it was rack and pinion. :-) 1996 to 1998 Grand Cherokee Jeep steering box.
"Everyone is entitled to be stupid sometimes, but you're abusing that privilege"
www.musclecarsgalore.com
www.nikivee.com
[www.reverbnation.com/nikivee
1967 Pontiac GTO
1967 Pontiac Grand Prix
1972 Pontiac Lemans Sport Convertible
2015 Dodge Challenger ScatPack 392, 6 speed
2017 Ford Explorer AWD
