Old 04-04-2019, 11:34 AM
STEELCITYFIREBIRD's Avatar
I would think too good down low ...but you have a strong low end cam 🤔 cross that when you get past ignition/tach.
You know what timing set is in it...part #, multi keys get some crossed up
Anyone else have any thoughts 💭
  #142
Old 04-04-2019, 11:57 AM
steve25 steve25 is online now
Just note that it is possible to have the firing order wrong and yet not have noticeable back fires and that would limit revs like mad.
  #143
Old 04-04-2019, 11:59 AM
TAQuest TAQuest is offline
Timing set on receipt says; PAW 513 Pont Rlr Timing Chn $17
  #144
Old 04-04-2019, 12:00 PM
Originally Posted by TAQuest View Post
Would it run good up to 3200 if the cam was way advanced?
Thanks.
Yes it would...Problem here is that cam should have awesome torque right off idle. Advanced any, within reason, it should be even stronger right off idle. As in, no need to rev it up to make power. Advanced beyond the 105° ICL, power would fall off at higher RPM's BUT it shouldn't quit at 3,200 like it's doing. Unless cam timing is way out of whack.
When cams are WAY OFF, the factory timing mark, on the balancer, usually doesn't match up or work right with where timing has to be set for the engine to run its best.
Clay
  #145
Checked that. Thanks.
  #146
Old 04-04-2019, 12:11 PM
I would think too good down low ...but you have a strong low end cam �� cross that when you get past ignition/tach.
Anyone else have any thoughts ��
Worked on a 455 years ago that had dots/squares/triangles all mixed up.
It was RPM limited and heated up fast (ran hot) if you reved it or tried to cruise at 3,000 RPM's. Idle to 3,000 was just okay on the power. No where near as strong as it should have been. Lots of loud carb moaning (like the OP's car) but wouldn't go anywhere.
Not saying that's what's wrong here. Just sayin'..
Clay
  #147
Old 04-04-2019, 12:12 PM
$17....purchased from?
Gears too? 😳
  #148
Old 04-04-2019, 12:19 PM
ta man ta man is offline
Swap a good module in see what it does.
  #149
Old 04-04-2019, 12:20 PM
Take the car somewhere that you can open the headers and then see how it revs.
If this was me I would have pulled the timing cover by now to see what may or may not be going on, just sayin!
  #150
Old 04-04-2019, 12:24 PM
Gears too? ��
PAW...Gone since 2010. And yes they did have full timing sets for cheap cheap. They also had better parts but the prices reflected that.
Clay
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
  #151
Old 04-04-2019, 12:29 PM
Stan Weiss's Avatar
OK, Pull the valve cover so you can see the valves for number 1. Rotate the crank until the mark on the balance lines up with timing mark. Make sure that this is the overlap TDC where both valves are open. If the intake valve is open more than the exhaust valve, the cam is installed to far advanced.
Stan
My Post #95
Stan
Pontiac Pump Gas List
  #152
Old 04-04-2019, 12:37 PM
Clay
Doesn't run hot. What are dots/squares/triangles all mixed up?
  #153
Old 04-04-2019, 12:43 PM
mchell's Avatar
mchell mchell is offline
No problems loading any video....that’s some crazy chit going on....you sure your exhaust isn’t plugged, air filter plugged etc..?
If not, I’d be checking the valves and cam timing soon...
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
  #154
Old 04-04-2019, 12:53 PM
All this messing around I haven't had the air cleaner on it. It's ram air.
The problem seems too consistent at an RPM to be exhaust plugged.
Always felt like the valves are bouncing.
Have to attend to some work. Will be swapping the module later this afternoon.
  #155
Old 04-04-2019, 12:55 PM
Three keyway timing sets that use the different keyways for straight up, advanced, or retard on cam timing. Cam gear had different dots to be used with each crank keyway. Mixing up dots/squares/triangles would get the cam way out of whack.
Not to be confused with ignition timing.
Degree wheel still needed to be used to make sure everything was right.
Clay
  #156
Old 04-04-2019, 01:06 PM
Stan Weiss's Avatar
X2
Stan
  #157
Old 04-04-2019, 01:35 PM
wbnapier wbnapier is offline
I had a similar issue, and it ended up being a bad coil. The engine would stop revving at 3500-4000 rpm. Thanks to this forum, I was able to diagnose it properly.
Good luck with this. Lots of good ideas here from knowledgable people.
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
  #158
Old 04-04-2019, 02:32 PM
I remember PRW well....bought from them......34 years ago. Wish I still had a catalog, handy, for my own use to ID a cam Used in my car.
....I know I have one buried in my Moms basement.
And old magazines with their ads.
If it turns out to be cam timing, a good opportunity to install an appropriate cam too.
  #159
Old 04-04-2019, 02:35 PM
I’ve run into the same at the track too with coils and modules in the stock car days. Both don’t like excessive heat. Burnt thru cheap rotors were an issue also, but different symptoms.
  #160
Old 04-04-2019, 03:03 PM
Navy Horn 16 Navy Horn 16 is offline
Originally Posted by pastry_chef View Post
I recall you had an interesting issue, in your case a little intermittent.
http://forums.maxperformanceinc.com/...65&postcount=1
What are the odds?
Yea, I was definitely sucking a vacuum on the tank. The Paul Harvey "rest of the story" on that one was that after I fixed the tank issue it was still acting funky when the secondaries would open.
That was being caused because the pin that holds the secondaries in so they can rotate open on that cam had come out. So the secondaries were opening all at once, or not at all, and it was causing hell with my fuel delivery.
My good friends at Quadrijet Performance LLC in Bandera, TX fixed it up for me on a drop in, and it's running good since.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, [email protected] in the quarter...still tuning.
