You realize it does take a little time to learn, you have to let it run and drive it some.
If the tune isn't good, and you are impatient, you can use a tuner, it's all over the phone/internet, and there not that expensive. There are others on here that have the same setup, and could even give you a baseline tune. If you need help with that, call me. 'Splices' usually work or don't. It's still not a lot of wires to give a tug on to figure out if it's 'bad'. Holley forums are not very good depending on where you post and who responds. 99% of all issues are user-caused, and then they blame the system. You get much better support if you email Holley. They will respond, get your phone number, and call you back pretty quick. Screw trying to call the support number. Once it's installed properly and running, you will never have to touch it again (for the most part). Just get over the initial hump and it's going to be the best experience, especially from a maintenance & reliability perspective. The best things never come easy. I have a tune on-hand you can use that would be very close if not right-on. You have my personal email, just ask. .
