Old 11-18-2019, 09:07 PM
Default Low VIN '70 Bird on eBay
This one has the lowest VIN of any I've ever seen. Base Bird, built 12C 1969. Same week as the other low VIN cars I've seen, so that must have been the pilot production week.
The car is in very rough shape...
https://www.ebay.com/itm/1970-Pontia...sAAOSwSeVd0vhk
Old 11-18-2019, 10:39 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Wow....that's cool!
Go fast, see Elvis!
Old 11-19-2019, 12:09 AM
unruhjonny's Avatar
the low build is neat, but there's not much there to start off with;
is that a fan shroud for an inline six?
1970 Formula 400
Old 11-19-2019, 08:14 AM
Don't know what that shroud is?
Off some other brand of car?
There is nothing left of the original car there really?
About everything removable is removed?
Interesting to see the PHS on that one.
Old 11-19-2019, 09:24 AM
T/A addict T/A addict is offline
Cool low production for sure but 10k? What the...... It's a basket full of "A whole lot of need"
Old 11-19-2019, 12:11 PM
77 Canamman's Avatar
Exclamation
Nothing special about that one other than the very early build..
My dog says, "RUFF"..
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 11-19-2019, 02:33 PM
necdb3's Avatar
necdb3 necdb3 is offline
Wonder what material the tail panel is made from if original?
Old 11-19-2019, 03:06 PM
Thumbs up
Old 11-19-2019, 03:10 PM
Lightbulb
Should be metal if original to the car.
Originally Posted by GETRIDAONE View Post
I have a 70 Firebird, Norwood build date 12C / 223870N100099 It has the pot metal panel. That blows the Van Nuys only theory.
Old 11-19-2019, 09:22 PM
1965gp 1965gp is offline
I’m confused- what am I not seeing? I agree 10k is high, but I don’t know that I would say it’s out of this world high for a running and driving 70-73? It is pretty beat up but I would think 5k would be light?
Old 11-19-2019, 09:36 PM
Formulabruce's Avatar
This one is # 223870N600035 Both these early cars are 6 cylinder cars. ( based on the Core support in the Ebay car) Car 00035 still retains its original driveline, and metal tail panel.
Old 11-20-2019, 12:25 AM
Lightbulb
Ebay car VIN is 223870N100013
The bold number one just to the right of the "N" denotes the car was born an eight cylinder.
The Following User Says Thank You to 77 Canamman For This Useful Post:
Old 11-20-2019, 01:08 AM
Ah, yes, that I did miss.
Old 11-20-2019, 01:20 AM
Wish people would stop calling everything a clone, especially when clearly not. Sure, it has one or two features that were found on a TA, hooray. You don't call a TA with plain hood an Esprit clone, it's a TA that is still in search of a replacement hood, or whatever. It's not a selling point, it's just a 50 year old vehicle with mismatched details. I'd have called it a Formula clone before a TA since the hood is more prominent than a few fender bits. Seen a lot worse get restored, or saved rather.
The Following User Says Thank You to Aus78Formula For This Useful Post:
Old 11-22-2019, 11:07 PM
FASTASSBIRD FASTASSBIRD is offline
Fiberglass. I asked
Old 01-01-2025, 10:10 AM
This '70 TA is on eBay right now. Norwood VIN sequence 100355; date code on trim tag is first week of January, 1970 (01A), although the car wasn't shipped until May 1970.
It's the earliest built '70 T/A I've seen from either plant. Has anyone seen an earlier '70 T/A VIN or Trim Tag date?
https://www.ebay.com/itm/16721115212...Bk9SR5SH7NCAZQ
Name:	PHS Invoice.jpg
ID:	645522   Click image for larger version
Name:	Right Front.jpg
Old 01-01-2025, 10:47 AM
Held for Ransom's Avatar
Was a 997 car, hence the 5%.
When did the WS4 start showing up on the tags?
So long, farewell.
Old 01-01-2025, 11:20 AM
Many years ago (mid-1980s, I think), I parted out an early 1970 T/A. I don't remember what the cowl panel data plate showed.
It was an oddity. It had the pot metal tail panel, the trunk pan had small round drain plugs in addition to the oval ones, and the WS block did not have the VIN stamped into it. Cast dates were late 1969. I ran the VIN and got the build sheet, this was back before PHS and Pontiac would send them to you for free. I also rememeber the PHS showing a 3 - 4 month difference between when it was built and when it shipped.
I have seen odd things before on a PHS. I found a rough 1969 GTO that the build sheet showed it was delivered to Pontiac engineering. The build sheet for this T/A didn't show anything to indicate where it might have been for those months. It was a 4-spd a/c car.
The Following User Says Thank You to poncho-mike For This Useful Post:
Old 01-01-2025, 02:51 PM
RLEngland RLEngland is offline
My buddy's 01C Norwood T/A has the WS4 on the tag. This one's the first Norwood car I've seen without it. This must have been a promo car. What is the 997 your referring too?
Old 01-01-2025, 02:57 PM
This one's a beauty. Maybe a promo car... There's an L100343 is listed on the SD Registry.
