Old 11-09-2023, 12:23 PM
Gach's Avatar
Gach Gach is offline
That 2-4 intake would sure look pretty in my car.
  #42
Old 11-09-2023, 12:52 PM
Gach's Avatar
I was thinking the Tri power but na, wouldn’t fit nostalgia look of a 70 GTO. I think guys would be drooling over 2-4 intake.
  #43
Old 11-09-2023, 01:06 PM
Gach's Avatar
I was thinking some mirrors to reflect that USA… logo, I wouldn’t want anyone to think its casted in China.
  #44
Old 11-09-2023, 05:36 PM
Dragncar Dragncar is offline
So how much HP was the fully ported Victor worth? Have any dyno sheets? Since in you other post you want to save people money. How much did fully porting the Victory cost?
Stan
You know better than to ask for a dyno sheet.
That Victor was cut in half ported and now weighs only a few pounds. Has over 2K just in labor in it.
Had a chance to buy it for 1250$ Sometimes I wish I would have.
But then he would not have it to build his Wilcox top end around and would not have it to build the BES Pro Port top end around either.
I would like to see how it turns out.
It might be so good we actually get a dyno sheet and ET slip !
But not sure how a intake ported to some 406cfm Gabby E heads is going to work on 480cfm Pro Ports. The PPs have got to have a bigger port. How much of that Victor is left ? Will it be welded up and further ported ? Then milled ?
Mike straight up told me any Victor could not keep up with his 414cfm E heads. So how does this all work ?
Jeff at KRE has got to have so much Pontiac heart and the desire to bring us all this new stuff despite the negativity he deserves some award for Pontiac Persistence !
No one is perfect, none of us.
  #45
Old 11-09-2023, 05:54 PM
Gach's Avatar
My loan just got approved. God thats going to look pretty under my hood.
  #46
Old 11-09-2023, 10:57 PM
grivera's Avatar
grivera grivera is offline
Thanks KRE for supporting the Pontiac community!
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
  #47
Old 11-09-2023, 11:00 PM
Tim Corcoran's Avatar
And making it in the USA
Tim Corcoran
The Following 3 Users Say Thank You to Tim Corcoran For This Useful Post:
  #48
Old 05-13-2026, 12:26 PM
Mike Davis's Avatar
This intake has been out a few years now. Besides KRE and Tin Indian Performance results, does anyone here have real world results?
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
  #49
Old 05-13-2026, 06:00 PM
Gary H's Avatar
Gary H Gary H is offline
Yes, I too would like to hear from some folks who have installed it.
  #50
Old 05-13-2026, 10:08 PM
slowbird's Avatar
slowbird slowbird is offline
I have one, just haven't had time to mess with it yet. Just looking at it my opinion is it will make decent power but due to the short runners the power below peak will be soft.
  #51
Old 05-13-2026, 10:29 PM
Mike Davis's Avatar
Brian is yours the 2x4 or 3x2 top?
421 CID
  #52
Old 05-14-2026, 05:13 AM
3X24SPD 3X24SPD is offline
I have 2 of the Tripower ones that I run with the Rochester carbs.
They're super nice intakes, and work really well.
Be advised that they do have some machine work that needs to be done before you can install them.
Both of mine req'd a .065" correction cut.
And you will need to do some grinding on the back of the intake and the distributor cap (stock points distributor) to open that interference up.
Also, the intake to cylinder head bolt holes need to be spot faced to get the bolts to sit flat on the intake.
The 2nd one I bought I had Jeff open up to 340CFM to match the E-Heads I have on the 469, and the 1st one was ported to 310CFM to match the E-Heads on a 464.
Here's some info from back when I bought/installed the first one:
https://forums.maxperformanceinc.com...d.php?t=867123
1966 GTO (Red) WARPATH
469CI TriPower 4-Speed
1965 GTO (Black) TRIPOWR
455CI TriPower 4-Speed
1965 GTO (Blue) 3X24SPD
464CI TriPower 4-Speed
1963 Tempest (Red) VIOLENT
440CI 2X4 Mag Nash / T400 (for now..)
  #53
Old 05-15-2026, 11:11 PM
slowbird's Avatar
I have both tops
