Ill see if i have pics of the 2 into 1 as well. Buts its #16 to #20. 4 into 1 are in stock and i have one 2 into 1 $135 & $145 i can add a radiator cap as well +50 |
So,do you tap and plug the water pump housing?Thanks for the pic's.
Yeah. From what I understand a lot of people do not use the bypass anyways. A lot of racers either just use a restrictor or drill holes in the thermostat.
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4. |
Sent you a PM John...
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
How would this work For My KRE Heads? Would U run a line to each in back ,and also to the two front one's too? Also street driven, So U plug the hole that normally goes to the cross over on the timing cover, and the nipple on the side of the timing cover too?
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
Got my water maniflod today. Very nice quality !!!
Thank you John.. Troy
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. Last edited by 60man; 02-06-2012 at 05:14 PM. |
Are these only for aluminum heads, or could they be used on factory iron heads as well?
Thanks, Russ |
If you get time could you post a pic of the two into one?Thanks,Lance
I ordered one of these today (finally!). Just thought I'd bump this back up for John!
If its one thing I know, its..... Uhhh I forgot .What do you mean I couldnt be the president of the United States of America, Its still WE THE PEOPLE, RIGHT!! ![]()
Got mine several weeks ago. Very nice piece.
www.hobracing.com |
[QUOTE=john marcella;4515616]This is one of my 4 into 1 water manifolds. It's set up for 4 #10 o-ring fittings (but you can use a combination fitting that is up to #12) and 1 #20 o-ring on the opposing side.
I also make a 2 into 1 water manifold. It uses 2 #16 to 1 #20. Both have provisions for NPT for water temp pick up. Anyone with a brand and part number for the #20 fitting? Thanks John
www.hobracing.com |
[QUOTE=jm455ho;4868284]
Jerry Bickel race cars or Rick Jones race cars has them, good price to. |
John do have anything for the 3rd Gen Bird body style which the radiator sits lower than the top of the block.
84 T/A w/ IA 2 -- 505 N/A w/ Tiger heads / BOP intake. "Best time" [email protected]/1.28 60ft. 77 Firebird formula 463 w TRW dome pistons w/ 4x's /edelbrock performer http://www.youtube.com/watch?v=KK163BxD9EY |
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
I will bring a few. Price has gone up though. 160$ My cost went way up on having them cut.
#38
John, may i ask, its such a long run all the way around motor and back to your home connector,wouldn,t been better just to go under the intake??
Saving my pennys, i got to have one of these, I love the looks!! Opps thought lines went around backside of motor, my mistake!! Senoir citizen momment!! |
#39
Nice work!
#40
got mine from jegs made by Meziere part number WN0032S this number is for a black fitting and they have other colors also.
"Three may keep a secret, if two are dead" ~ Benjamin Franklin ~ |
