Old 07-01-2012, 01:25 PM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Anyone got log manifolds then??
Thanks,
Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 07-02-2012, 05:53 AM
zeebo's Avatar
zeebo zeebo is offline
i believe PY sells them repop, or look on ebay..they usually have some for sale...keep an eye out for boogered up threads/studs.....
Old 07-02-2012, 08:38 AM
SOmething like this?
http://www.ebay.com/itm/1976-Pontiac...56e063&vxp=mtr
The Burb Files
Old 08-20-2012, 04:08 PM
Originally Posted by 1967Tempest View Post
I asked him yesterday and he assured me that it was a TH350..
Thanks!!
Well, it looks like when I asked him to check and got the word yes, it meant I didnt look at all. Now it might be a TH200. Other than the tranny not holding up to 99 more cubic inches and the associated hp and tq, will it bolt up???
Thanks!!
Dave
The Burb Files
Old 08-20-2012, 07:25 PM
goatwgn goatwgn is offline
Thanks!!
Dave
Yes, it will bolt up. You will have to hook up the TV cable to get it to work properly. Good luck.
Old 08-25-2012, 11:40 PM
Or what?? It is a TH200. AS there is no vacuum modulator.
Actually this is going rather well.. A few setbacks, but not bad. The starter for the 301 will start a 301 and that is it. Upgraded to a regular 400 starter. Should have it running tomorrow...
Thanks again!!!
Dave
The Burb Files
Old 08-26-2012, 10:10 AM
The TV cable on the TH200 should move about 1 and 1/8th inch from wide open throttle back to idle. It should be pulled out all the way at full throttle. Using the setup on the 301 as a guide should put you in the right ballpark. The TV (throttle valve)cable combines the functions of the Vacuum modulator and the downshift in one valve assembly.
Old 08-26-2012, 10:41 PM
Groovy!!
Well we tried to get the car running today. No dice. We had it running for a minute or so at 2000 rpms good oil pressure etc.. But I tried to check the timing and it died. Now I was so burned out from trying to get everythng ready, I might be over looking something, but I checked the firing order 10 times and tried the 180* out route as well.
BUT, the carb (Edelbrock 1405) has spit fuel out of the top no matter what, even when it WAS running. So I think that might be an issue as well. Might be flooding it...
Any ideas?
The Burb Files
Old 08-26-2012, 11:51 PM
Likely a sticking float. Try tapping on the side of the carb. If that doesn't work, you may have to disassemble it.
Old 08-27-2012, 08:14 AM
Yeah, thats what it sounds like. The crappy thing is it makes you chase your tale for the 180* out timing thing. I think the engine is just badly flooded. Ill try the float. I guess even brand new carbs have issues!!!
Could be something from the line suck in the seat too..
The Burb Files
Old 08-27-2012, 10:02 AM
AYE Carumba!!!!!!!!!!!!!!!!!!!!!!!!!
The floats are not a hair off they are WAY!!!! off!!!!! almost 1/4" off in the down and up position. Ill readjust and report~!~
Thanks!!!
The Burb Files
Old 08-27-2012, 12:42 PM
WINNER!!!!! starts like a new car!!!
The Burb Files
