Old 03-19-2014, 07:57 PM
Transporter Transporter is offline
Originally Posted by J.C.you View Post
what kind of numbers did Kaase do with his EM pump gas poncho years ago?
Kaase was 507 CI with 820 hp at 767 TQ
But remember this was on 91 octane and 6500 rpm.
Old 03-19-2014, 08:19 PM
tom s tom s is offline
Engine was sold to a customer in WA state I believe.Tom
Old 03-20-2014, 10:15 AM
dci dci is offline
If I remember correctly, Kaase's 507 torque curve did not drop below 700 ft lbs. from 3700-6300 rpm. He told me the engine actually made over 850 HP on pump gas. If you could hook that thing up in a street car. It would tear it in half LOL.
Don Johnston
DCI MOTORSPORTS INC.
330-850-5050 shop
330-628-3354 cell
Designer of the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
Old 03-20-2014, 10:46 AM
Stan Weiss's Avatar
Don Johnston
330-850-5050 shop
330-628-3354 cell
Don,
I have these numbers in a file on my computer. I am not sure where I got them from.
RPM Torque
2500 619.6
3000 622.8
3500 694.8
4000 733.2
4500 761.4
5000 783.6
5200 786.2
5500 762.6
6000 736.6
6200 721.5
6500 667.0
Stan
Pontiac Pump Gas List
Old 03-20-2014, 11:36 AM
RAMAIR RICK RAMAIR RICK is offline
Chris Uratchko, short of making a Jon Kasse remake, how might someone go about making a 92-93 REAL pump gas, street/strip engine that many people may build without highly specialized parts? Say the Hp target is 800 to 850hp in an rpm range more like 6500-7500, which be driven on the street and later raced the same day. From this baseline engine package design many could then step up to 850-900 to 900-950 to 950 to 1000 hp. Each step in a NA engine may require stretching the minds of some people to do it. I really think it will be VERY GOOD for this Pontiac community, as our Passion is the love of Pontiacs, and the desire to drive them, race them, and show them off.
Old 03-20-2014, 11:56 AM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Chris gave a baseline in post #9 and Bill C said what they have going in post #12.
Great flowing heads and big CID to start...
Old 03-20-2014, 11:59 AM
Stan Weiss's Avatar
Just what heads (castings) with who's porting do you plan on using
Since this is the 1000 HP thread and not the 2.3 HP per ci thread, build as large an engine as you can. Part of the scoring in the EMC was ci's, so in other words HP per ci played a part in the way Jon designed his engine.
Stan
Old 03-20-2014, 12:24 PM
john marcella john marcella is offline
Stan
Heads and manifold are already done, cid is figured out as well as everything else for the most part. All you have to do is wait a little bit and you will see OVER 1000 on 93 pump crap. IMO Oh by the way, with 1 carb.
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
Old 03-20-2014, 07:42 PM
Chris Uratchko Chris Uratchko is offline
Pontiac pro port heads and a wicked cast intake. I'll post updates. 540 cid.
Uratchko Racing Engines
www.ure-racing.com
Old 03-20-2014, 07:54 PM
mjm421's Avatar
mjm421 mjm421 is offline
So some Pontiac powered pump gas Firebird is going to make more power than Marcella's race car!
Mike McCarty You can drop the line, but you'll never kill the spirit!
Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far
Old 03-20-2014, 09:13 PM
mike leech's Avatar
mike leech mike leech is offline
you will NOT get there without specialized parts....period. otherwise they would be common.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 03-21-2014, 12:46 PM
I am curious, as the theme to acheive Hp to get to 1000 hp or more, is to build a bigger engine, then why have so very many people shy away from the 4.75 strokes and 565-571 ci.??? Is there an issue in the geometry of stroke in the bottom of the bore in the aftermarket blocks and how it relates to the wrist pin? From the engine builders out there, please give your input. Otherwise many more may people may want to step up if the safety/longevity is not and issue. I know some people have built the 4.75 stroke large inch engines, is it worth it??
Old 03-21-2014, 01:19 PM
Stan Weiss's Avatar
I believe this (how much piston is coming out of the bottom of bore ABDC) has been talked about before. On the IA 2 block does anyone know the length of the shelve.
Stan
Old 03-22-2014, 09:35 AM
dci dci is offline
Definitely smarter to use more cubes, but it will still need to make around 1.9 HP per cube. Hard to believe just a few years ago if someone made anywhere close to 2 HP on race gas they were the King. Now we are talking about making that with pump piss LOL. Pontiac's are alive and going strong!!!! I love it!!!!
Don Johnston
330-850-5050 shop
330-628-3354 cell
Old 03-24-2014, 08:28 AM
dci dci is offline
Chris, Why did you choose the pro port and not a Tiger or high port? Not trying to put you on the spot, just curious. If your using John M's pro ports and tweaking them a little, that makes perfect sense.
Don Johnston
330-850-5050 shop
330-628-3354 cell
Old 03-24-2014, 01:16 PM
Well, on the heads I like the over all design of what we can do in the pro port. It's a more modern design in my opinion.
My customer purchased a set of Pro Ports raw and we were going to do the whole deal from scratch and then Marcella wanted to sell his engine. So we bought Marcellas engine, with no rotating assembly or intake manifold, and we're attacking it from that angle. John has a lot of work in the heads that would take a lot of man hours to duplicate, and it's all top shelf quality parts inside and outside the engine. So we get a good foundation to build on.
www.ure-racing.com
Old 04-01-2014, 06:47 PM
Chris, I am curious, what true static compression would you build a 92-93 octane true pump gas at with a carb. or multipart EFI?? Knowing the engine would be at least 540ci. and have some stroke in it. Also how radical would the cam duration and NET LIFT be to achieve the 1000hp mark? Lastly, how much smaller could the cam be to be a 800-850hp street/strip 92-93 octane pump gas, 540ci. or larger engine?? Example would the NET LIFT and or the cam durations change greatly from the 1000hp engine? Thanks in advance for your response.
  #38
Old 04-01-2014, 08:04 PM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
... now this is what a real mean pump gas engine looks like ...
  #39
Old 04-01-2014, 10:39 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Looks like POS Chevy Hemi.
Non Pontiac = don't care.
First Pontiac powered street car in the 7's
[email protected]. 3460#s
  #40
Old 04-01-2014, 10:41 PM
... same can be said about your opinion ...
