Old 11-09-2023, 11:11 AM
J.C.you's Avatar
J.C.you J.C.you is offline
Originally Posted by slowbird View Post
Nope you're not knocking it all, not in the least.
🤣, first he said cheap china, and not supporting American jobs, then proven wrong,…. now the intakes are too expensive being made here by American workers 🤪.
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
Old 11-09-2023, 12:23 PM
Gach's Avatar
Gach Gach is offline
That 2-4 intake would sure look pretty in my car.
Old 11-09-2023, 02:16 AM
Dragncar Dragncar is offline
Originally Posted by 694.1 View Post
That Aluminum OHC head has got to be right around the corner!
One can only hope that is one of the things that Jeff said is right around the corner.
But the anti KRE crowd will knock that too.
Can you imagine "all the dollars" it would take to finish a OHC PONTIAC now !!!
Forgetting all the thought and effort it takes to bring these types of things to the public.
Old 11-09-2023, 10:57 PM
grivera's Avatar
grivera grivera is offline
Thanks KRE for supporting the Pontiac community!
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 11-09-2023, 11:00 PM
Tim Corcoran's Avatar
And making it in the USA
Tim Corcoran
The Following 3 Users Say Thank You to Tim Corcoran For This Useful Post:
Old 05-13-2026, 12:26 PM
Mike Davis's Avatar
This intake has been out a few years now. Besides KRE and Tin Indian Performance results, does anyone here have real world results?
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 05-13-2026, 06:00 PM
Gary H's Avatar
Gary H Gary H is offline
Yes, I too would like to hear from some folks who have installed it.
Old 05-13-2026, 10:08 PM
slowbird's Avatar
slowbird slowbird is offline
I have one, just haven't had time to mess with it yet. Just looking at it my opinion is it will make decent power but due to the short runners the power below peak will be soft.
Old 05-13-2026, 10:29 PM
Mike Davis's Avatar
Brian is yours the 2x4 or 3x2 top?
421 CID
Old 05-15-2026, 11:11 PM
slowbird's Avatar
I have both tops
Old 05-14-2026, 05:13 AM
3X24SPD 3X24SPD is offline
I have 2 of the Tripower ones that I run with the Rochester carbs.
They're super nice intakes, and work really well.
Be advised that they do have some machine work that needs to be done before you can install them.
Both of mine req'd a .065" correction cut.
And you will need to do some grinding on the back of the intake and the distributor cap (stock points distributor) to open that interference up.
Also, the intake to cylinder head bolt holes need to be spot faced to get the bolts to sit flat on the intake.
The 2nd one I bought I had Jeff open up to 340CFM to match the E-Heads I have on the 469, and the 1st one was ported to 310CFM to match the E-Heads on a 464.
Here's some info from back when I bought/installed the first one:
https://forums.maxperformanceinc.com...d.php?t=867123
1966 GTO (Red) WARPATH
469CI TriPower 4-Speed
1965 GTO (Black) TRIPOWR
455CI Weiand Dragstar with 6 Strombergs
4-Speed
1965 GTO (Blue) 3X24SPD
464CI TriPower 4-Speed
1963 Tempest (Red) VIOLENT
440CI 2X4 Mag Nash / T400 (for now..)
