Old 09-12-2024, 02:05 PM
mgarblik mgarblik is offline
I certainly understand Paul's point about the pistons. Having to make some valve pocket corrections to fit new heads is certainly not a show stopper for me. But I have a Bridgeport and a BHJ super nice piston vise. So once set-up, could cut 8 pistons in about an hour. About 1 hour to set-up and an hour to cut. However, if I was just changing heads and not even pulling the engine, this could be a deal breaker. Or even worse, not checking and just throwing the heads on expecting them to work. I do feel confident Don would have detailed information about what is required to have success with the heads once ready to sell them. I am sure he wants a successful outcome as much as anyone.
  #142
Old 09-12-2024, 02:19 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by Stan Weiss View Post
It seem people want this head to just be plug and play.
So I am just curious what would you be replacing if you bought these heads
1) Basically stock or close to stock Cast Iron Heads
2) Highly ported Cast Iron Heads
3) Someone else's Aluminum Head
Stan
Hi Stan, that's an interesting question. I'd consider a pair for my 70 TA. They'd replace the current 614 heads that are on a fresh engine, so they'd need to be a bolt on deal. It would be nice if they'd accept the factory head bolts.
Go fast, see Elvis!
  #143
Old 09-12-2024, 03:00 PM
Dragncar Dragncar is offline
Would there be any meaningful performance advantage to the way Don originally wanted to make them vs bolt on ?
If it does not add up to a hill of beans make them bolt on, all accessory bolt holes and accept factory head bolts.
One would think that sales wise, he would sell far more bolt on.
The Following User Says Thank You to Dragncar For This Useful Post:
  #144
Old 09-12-2024, 03:21 PM
jhein's Avatar
jhein jhein is offline
That's exactly what I've been thinking.
  #145
Old 09-12-2024, 03:23 PM
What would be the point of having them mimic the looks of a factory head if they’re not targeted for the street performance crowd that for the most part would want a bolt-on head that doesn’t require special pistons and also accepts factory accessory brackets?
It’s nice that some factory casting numbers will be available on these, but if that’s just a novelty on top of a more race oriented offering I guess I’m missing something.
At least half of the buyers will want to bolt these on their already built shortblock that are already running stock or modified iron heads either round or D-port. People even like to bolt aluminum heads onto completely stock short blocks, whether that’s a good idea or not.
Yeah I get that hot rodders should be expected to modify their stuff in order to use certain parts, but a majority don’t want to tear down their engines to extract the pistons and machine the valve pockets just to bolt on some cylinder heads. These really should be offered as a bolt-on to accommodate the wants and needs of the majority of potential customers.
If making money is the aim then aim for your target audience.
The Following 2 Users Say Thank You to b-man For This Useful Post:
  #146
Old 09-12-2024, 03:46 PM
PAUL K's Avatar
Not sure exactly "how much" power moving the valves around would be worth. It's usually used for top shelf class builds with restrictions on the heads looking for that last ten horsepower. Edelbrock moved the exhaust valve over .050 to allow the use of a larger intake valve in the stock location. Just that one move caused issues with Edelbrock's test engine used for the development of the Victor manifold. The exhaust valves nipped the side of the pocket.
I believe I mentioned this earlier but a 2.11 valve will easily support 800+ HP without being moved.
A 1.66 exhaust will easily support 900+ HP
Over 1200hp has been made using standard Edelbrock valve locations.
IDK Don's reasoning for the valve locations and sizes he chose. I don't want to speculate. He's a smart man and I'm sure he has a specific buyers he wants to target.
Go fast, see Elvis!
  #147
Old 09-12-2024, 04:17 PM
Stan Weiss's Avatar
At least half of the buyers will want to bolt these on their already built shortblock that are already running stock or modified iron heads either round or D-port. People even like to bolt aluminum heads into completely stock short blocks, whether that’s a good idea or not.
If in fact these heads flow the rumored 300 cfm. Then IMO someone replacing a stock head without doing any other changes will not be happy.
Stan
Pontiac Pump Gas List
The Following User Says Thank You to Stan Weiss For This Useful Post:
  #148
Old 09-12-2024, 04:44 PM
Stan
Exactly why I wrote this in my post that you quoted:
And, there’s not a single thing wrong with that. The same heads that someone might first use on a stock shortblock can be used later on for a better build.
Just because they’re a 300 cfm head doesn’t mean they won’t run, of course not up to their full potential but they’re going to be fine.
Kinda like the LS3 that has a 320 cfm head as delivered making 430 hp. Just by adding headers and a better cam you end up with 500 to 550 horsepower because the heads have the capability to get you there in the future.
  #149
Old 09-12-2024, 06:26 PM
Stan Weiss's Avatar
I only had a rough idea what the LS cam specs were. This what I got when I did a google search.
Stock LS3 Cam Specs: 204/211 duration, 0.551/0.525 lift, 117 lobe separation angle, 1.7:1 rocker arm ratio.
Stan
  #150
Old 09-12-2024, 06:29 PM
jhein's Avatar
He's got a new video out that I haven't had a chance to watch entirely yet, just watched a bit of the beginning. What he was saying is that even though they flow 300+, that his design still allows for good velocity at lower flow rates. At least that's what I understood (?). But, I'm not an expert on that and I didn't watch the whole video.
The Following User Says Thank You to jhein For This Useful Post:
  #151
Old 09-12-2024, 06:30 PM
Stan
Exactly what mine has in it.
So it’s an engine that is cammed for low speed efficiency and still runs readily up the 6600 redline because it has plenty of head flow.
Just adding headers gets you up to 480 horsepower.
  #152
Old 09-12-2024, 06:39 PM
PAUL K's Avatar
Stan
The bigger cam core is a huge advantage for the LS engines. It allows a lot of lift with short duration.
Go fast, see Elvis!
  #153
Old 09-12-2024, 06:44 PM
Stan Weiss's Avatar
Stan
Above is my original post. I didn't say the DCI heads could not be made to work. But how many stock head Pontiac have a cam like the LS3? High lift short duration.
Stan
  #154
Old 09-12-2024, 06:57 PM
Stan
Few to none I’m sure.
But quite a few have something in the range of a RAIV cam.
Many Pontiac street engines are just like that, and many will buy a bolt on aluminum head that’s reasonably in line with the cost of ported iron heads. The cost to rebuild iron heads properly and then the porting work added to that is within a few hundred dollars of new aluminum heads.
A good number of engines out there right now have the heavy TRW or Sealed Power forgings in them hanging on stock rods or maybe inexpensive forged rods. A new aluminum head that will work with that is what’s going to sell in my opinion.
So whatever Don decides he’s going to market is his choice not mine or anyone else’s, let’s hope he sells a lot of them.
  #155
Old 09-12-2024, 08:08 PM
Stan Weiss's Avatar
If we want to compare with an LS.
I have a Audie CPP report from a Tooly Stage 2 cam
279/292 @ 0.006" | 227.6/235.2 @ 0.050" | 0.36178"/0.33859" lobe lift | 0.61502"/0.57560" At Valve with 1.7:1 | 112.8 LSA | 109.8 ICL/ 115.8 ECL
Stan
  #156
Old 09-12-2024, 08:42 PM
The point I’m trying to make is this head should bolt onto the average Pontiac guy’s shortblock.
Who gives a damn whether or not that 300 cfm head would be disappointing or not, it’s up to the buyer to decide to cam it, induct it and exhaust it to get the most out of it.
Or not.
If it’s useable for the larger spectrum of potential buyers it’s going to be a winner.
  #157
Old 09-12-2024, 08:53 PM
Everybody can probably agree that Don-DCI is a smart guy.
And the heads will be great performing heads.
Seems like to me they are going to be more of an upper scale niche/boutique item.
So that must be the target he is banking on.
He probably has enough client base in the 550-600+ hp resto-mod category to cover doing the project.
Roundport 72cc Eddy's dropping to $2200 pair with free shipping is going to strike a blow though.
Black Friday coming up soon too.
Guys not trying to make 550-650hp will more than likely take the savings over the casting numbers and the extra cfm.
That's just my old school opinion.
I don't think the new school and resto-mods even care about block codes and head numbers.
And these probably won't ever get approval by any restricted class racing sanctions.
Wish Don the best with them all the way.
Out of my league
  #158
Old 09-12-2024, 11:29 PM
jhein's Avatar
So I watched as much of the new video as I could. He does say that his intake port is designed for high flow but also maintains high velocity even at lower cfm for things like even 350 cid motors. Maybe even more importantly, he eventually says that he wants you to be able to pull off your set of factory iron heads and swap a pair of his heads right back on your motor.
  #159
Old 09-12-2024, 11:31 PM
Don is a member here.
He can post whatever info he has on them and then we can all better understand everything about his heads.
  #160
Old 09-12-2024, 11:41 PM
PAUL K's Avatar
That's good.... I wonder if the "haters" and "nit pickers" had anything to do with the "bolt on" decision..... Hmmmm
Go fast, see Elvis!
