Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 2
1
2
Showing results 1 to 25 of 41
Search took
0.19
seconds.
Search:
Posts Made By:
pfilean
Forum:
Heating & Cooling TECH
07-14-2026, 11:05 AM
14
thermostat thoughts
230
Posted By
pfilean
I tested the old 180 thermostat and it started to...
I tested the old 180 thermostat and it started to open at 180 as advertised. Also tested another old RobertShaw I had from somewhere. It was a 160 and opened at 160 but I didn't use it because I...
Forum:
61-66 Big Pontiac TECH
07-07-2026, 09:59 AM
9
Post up your aftermarket AC install
182
Posted By
pfilean
search for posts VinAir in 61 Pt1 and Pt2 as one...
search for posts VinAir in 61 Pt1 and Pt2 as one way
Forum:
06-11-2026, 10:00 AM
3
Battery terminal orientation on a '65 Bonneville
586
Posted By
pfilean
I would think they were always negative nearest...
I would think they were always negative nearest to the engine so the negative cable would go right to a Bolton the front of the head to maybe to some bolt on an accessory bracket. The positive would...
Forum:
The Body Shop TECH
05-09-2026, 01:34 PM
19
Paint for Emblem?
956
Posted By
pfilean
I have used the duplicolor tube with the brush...
I have used the duplicolor tube with the brush included. same stuff I use to touch up little chips on the other parts of the car.. As suggested the little excursions outside the lines come off easily...
Forum:
11-19-2025, 01:17 PM
5
What Makes Pontiacs Run?
643
Posted By
pfilean
What Makes Pontiacs Run? 5
Last
Forum:
11-19-2025, 01:08 PM
5
643
Posted By
pfilean
Recently refound this old article that I find interesting. Considering how tings are done now maybe only of nostalgic value but I searched and couldn't find that anyone had posted it before. Maybe...
Forum:
08-20-2025, 10:22 AM
11
TH350 in 63 2 dr hardtop Cat ???
675
Posted By
pfilean
I put a 350 in my 61. Needed an adapter because...
I put a 350 in my 61. Needed an adapter because of the starter problem and also my 350 was a Chevy bolt pattern. There are two nice adapters I know of maybe more. Although delivery maybe a problem...
Forum:
Pontiac - Street
04-13-2025, 09:49 AM
21
Unfortunate truth.
1,937
Posted By
pfilean
Been there many times. But this reminds me of...
Been there many times. But this reminds me of what once was called O'Leary's corollary to Murphy's Law which states "Murphy was an optimist".
Forum:
01-17-2025, 11:39 AM
5
66 Full Size 4 Speed Pedal Help
2,238
Posted By
pfilean
I would need to do more research but as a quick...
I would need to do more research but as a quick suggestion did power brake cars use a different pedal pivot point than may have been used for manual brake cars. 66 full size probably had a lot more...
Forum:
Electrical Tech
10-21-2024, 09:56 AM
3
Weird Dash Light Gremlin
1,713
Posted By
pfilean
Grounds will drive you crazy. For most...
Grounds will drive you crazy. For most unexplainable electrical problems look at the grounds. Had a problem on an old truck recently. Turn on the parking or headlights an everything in the dash...
Forum:
Tri-Power Tech
08-10-2024, 12:02 PM
2
'63 389 Tripower upper rad hose
3,667
Posted By
pfilean
That is probably right. There is a 1961 Craftsman...
That is probably right. There is a 1961 Craftsman note to cut about 1 inch (IIRC) out of the radiator end of the hose that was a big sweeping curve. That moved the hose away from the air cleaner and...
Forum:
Pontiac - Street
08-09-2024, 10:09 AM
23
Ditched my Petronix
3,084
Posted By
pfilean
Dumped the Pertronix the PO put in my 61 several...
Dumped the Pertronix the PO put in my 61 several years back due to several little problems I could find no other explanation for. Starts right up, idles smooth, no flat spots. and no unexplained...
Forum:
04-13-2024, 11:51 AM
3
Kick panel leaks
1,345
Posted By
pfilean
What I have seen is happen is a result of...
What I have seen is happen is a result of original design.
The cowl vent is the opening that allows air through the kick panel vents. The cowl around the vent is a chamber that may have a 1 inch...
Forum:
Pontiac - Street
03-31-2024, 09:06 AM
13
What tool?
2,029
Posted By
pfilean
I'm to cheap to go looking for an expensive tool....
I'm to cheap to go looking for an expensive tool. I often just solder on a ferrule from compression fitting. It's a little too big, so you then have to grind off some of it. I know it doesn't look...
Forum:
Pontiac - Street
02-22-2024, 10:53 AM
28
Points style distributor cap & rotor source?
4,215
Posted By
pfilean
I use NAPA Echlin RR165 cap and RR1670 rotor.
Forum:
Tri-Power Tech
12-21-2023, 11:13 AM
5
Vacuum to Mechanical Tri-Power Conversion Question
2,466
Posted By
pfilean
Looks like he older mechanical that I thought was...
Looks like he older mechanical that I thought was discontinued in 64 in favor of the later style that was not as likely to be installed wrong.
Forum:
The Body Shop TECH
12-21-2023, 11:09 AM
3
Weather stripping
1,370
Posted By
pfilean
Steele Rubber
Steele Rubber
Forum:
Tri-Power Tech
11-03-2023, 09:17 AM
15
Center Carb Leaking When Engine Shut Off
4,865
Posted By
pfilean
Regardless of what you decide about the...
Regardless of what you decide about the needle/seat and float level adjustments also check the wear on the throttle shaft. The drivers side where you see the leaking gets more load as it is the side...
Forum:
The Body Shop TECH
10-04-2023, 11:16 AM
3
61 Catalina Wheel well
1,391
Posted By
pfilean
Here are three pictures. These are not original...
Here are three pictures. These are not original but when I replaced the rockers I tried to make it look like it once was. This can be a bad area because if the rear window has leaks the drainage...
Forum:
Pontiac - Street
07-16-2023, 09:33 AM
82
Mechanical fuel pump and electric pump. ?
20,947
Posted By
pfilean
I just wanted a priming system for tri-power to...
I just wanted a priming system for tri-power to be used after long inactive times with all gas evaporated from carbs. Hard on starters with extended cranking to fill carbs.
First used the...
Forum:
04-30-2023, 11:07 AM
9
63 and a half or 64 Pontiac Catalina
1,602
Posted By
pfilean
What I see is a 64 that has been wrecked and had...
What I see is a 64 that has been wrecked and had a 63 front clip put on. If they did that I would start looking for damage that may not have been repaired well. Like frame and suspension.
Forum:
Pontiac - Street
04-25-2023, 11:10 AM
71
What is up with tire mfgs lately?
12,548
Posted By
pfilean
Track73 That's how I remember it from my days...
Track73
That's how I remember it from my days at Goodyear back in the 60s. Tires going for OEM got a wax dot at the light spot. Was supposed to mount at the valve so less weight would be needed. ...
Forum:
Pontiac - Street
11-06-2022, 12:06 PM
22
Disc brake upgrade big body
2,824
Posted By
pfilean
It gets confusing learning what interchanges. A...
It gets confusing learning what interchanges. A body, B body what year did this or that change and when may A or B body use the same.
I have a 61 Ventura (OK, call it a B body). I have C3...
Forum:
Pontiac - Street
10-07-2022, 10:36 AM
37
Factory Indian Head logo on 64 head ???
3,945
Posted By
pfilean
If someone made those by grinding down with a...
If someone made those by grinding down with a Dremel they sure have a steady have to get the flat surface that true. A real artist.
Forum:
07-16-2022, 03:57 PM
10
Slim Jim swap
1,469
Posted By
pfilean
Just as a first thought - is it possible that for...
Just as a first thought - is it possible that for some reason, like maybe a previous owner had to do engine work, that you now have a crankshaft from a manual transmission car that has a pilot...
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
01:15 PM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
