Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 2
1
2
Showing results 1 to 25 of 30
Search took
0.04
seconds.
Search:
Posts Made By:
Scott Thelander
Forum:
69-71 Judges only TECH
08-02-2025, 11:33 PM
15
Side Mirror Date Code
2,333
Posted By
unruhjonny
12-DMI-1 December - 1971 an early life...
12-DMI-1
December - 1971
an early life replacement.
Forum:
THE LOBBY
07-24-2025, 08:23 PM
21
1970 Judge hood bump?
1,343
Posted By
BOB VIDAN
More beer!!!!!!!!!!!!!!!!!
Forum:
70-73 Firebird & TA TECH
04-20-2025, 05:24 PM
12
correct coil(s)?
1,212
Posted By
Transamric
My '70 VN RAIII TA has it's original #410 also. ...
And Jonny, I think you're correct about the printed numbers on a coil indicating it was a later issue service replacement.
Forum:
04-20-2025, 05:08 AM
12
correct coil(s)?
1,212
Posted By
Kenth
AMA on 1970 V8 Coils: (#1115238 is the SR coil)
Forum:
66-67 GTO Tempest & LeMans TECH
03-29-2025, 11:26 AM
7
Rally 2 wheel code confusion
1,518
Posted By
'ol Pinion head
JA is the wheel ID code. -Big letter JA or big...
-Big letter JA or big letter JC were stamped through '67 production up into mid May of '68 when small letter wheel ID codes & external date codes began. The big letter code...
Forum:
02-19-2025, 08:11 PM
4
1966 GTO ignition switch question
2,037
Posted By
GT182
Domarinolo, if you don't have it back together...
Domarinolo, if you don't have it back together and want the parking lights on with the headlights, do this.
Take the purple wire off of Tab 7 it's on and move it to the front left side of the of...
Forum:
69-77 Grand Prix TECH
06-07-2024, 08:33 AM
2
removing 69 GP console plate
2,611
Posted By
comanchefirebird
You will have to completely remove console to R...
You will have to completely remove console to R and R the shift plate.
Pull shifter button and remove knob. Remove two large screws in upper front corners of console that go up into dash, pull the...
Forum:
68-69 GTO Tempest & LeMans TECH
05-24-2024, 04:07 AM
6
Front brakes dragging.
1,871
Posted By
gtohurstjudge
If you are running a reproduction brake booster,...
If you are running a reproduction brake booster, that is your problem. On these boosters the push rods are slightly too long. What I did on all my cars is put one washer on each booster stud before...
Forum:
05-21-2024, 06:35 PM
6
1,871
Posted By
Scarebird
Make sure the booster push rod is not too long.
Forum:
THE LOBBY
05-17-2024, 12:15 PM
101
Greg Reid needs us
14,684
Posted By
Shiny
Thank you for relaying this news. It's awful to...
Thank you for relaying this news. It's awful to know he's suffering in any way. He's been a big support for me over the years on PY and I am grateful for all the positive posts he's shared.
Greg...
Forum:
03-27-2024, 08:22 PM
2
69 A Body Sideview Mirror
1,182
Posted By
gto4evr
it's done all the time, bugs me as a purist when...
it's done all the time, bugs me as a purist when it comes to mirrors but I'm also stuck with the non matching mirrors due to having a 69 remote. I haven't been able to bring myself to do anything...
Forum:
12-27-2023, 11:31 PM
8
'68 / '69 Timing Cover Differences?
1,733
Posted By
JSuchma
Correct, in 1969 there was a short and long...
Correct, in 1969 there was a short and long version of the 11 bolt pump.
Forum:
12-16-2023, 06:33 PM
3
Ignition Switch Removal 1968?
1,751
Posted By
rt400
Turn the key to the left. Insert a paper clip and...
Turn the key to the left. Insert a paper clip and push it in while continuing to turn the key to the left. Cylinder should pop out.
Forum:
Electrical Tech
12-10-2023, 03:34 PM
12
Lights intermittently brighten then go back to normal
5,639
Posted By
hgerhardt
I'd blame the voltage regulator if you see this...
I'd blame the voltage regulator if you see this problem with both the headlights AND the instrument lighting at the same time.
Forum:
Pontiac - Street
10-12-2023, 03:56 PM
29
Won't start
3,181
Posted By
steve25
It’s plain & simple to me what’s going on. 1)...
1) he see’s Spark , yet the motor will not kick with starting fluid being used.
2) this can only mean that the spark that he does see is so weak that...
Forum:
Pontiac - Street
09-29-2023, 02:46 PM
34
clutch wont release
5,258
Posted By
HWYSTR455
Just to say it out loud, you should always shift...
Just to say it out loud, you should always shift into 1st before you go into reverse, reverse is not synchronized.
Forum:
Pontiac - Street
09-27-2023, 11:22 AM
34
clutch wont release
5,258
Posted By
abefromen
Short head ARP bolts were used. No witness marks...
Short head ARP bolts were used. No witness marks on anything. I test fit the disc to the flywheel beforehand and it fit flat no touching.
Definitely in correctly. If it was backwards it...
Forum:
Pontiac - Street
09-22-2023, 06:56 PM
10
Can't mount Hurst to Muncie
2,145
Posted By
'ol Pinion head
Incorrect mtg plate, possible incorrect shifter linkage.
'69 Camaros with performance small blocks & a Muncie 4 speed received the exact same factory installed HURST shifter as '69 V8 Firebirds with the Muncie 4 speed. '69 396 & 427 Camaro's used the same...
Forum:
09-05-2023, 04:08 AM
6
69 tail harness
817
Posted By
gtohurstjudge
My 69 GTO convertible has a plug in connector for...
My 69 GTO convertible has a plug in connector for all the wires located near the left trunk hinge,so the tail lamp harness is separate from the ribbon harness under the carpet. All the harnesses in...
Forum:
70-72 GTO Tempest & LeMans TECH
09-03-2023, 06:19 PM
10
Missing screws for seat back bumpers
1,111
Posted By
67drake
I don’t have a thread pitch gauge, so this is all...
I don’t have a thread pitch gauge, so this is all I can do. HTH I’m the second owner of my GTO , so pretty sure it’s original.
BTW, I see you’re in central Fla. I have a son in Deland.
Forum:
Pontiac - Street
08-31-2023, 09:56 AM
20
Power steering pump squeal
3,752
Posted By
george kujanski
Belt width correct? too narrow and the belt runs...
Belt width correct? too narrow and the belt runs in the bottom of the grove rather than the sides.
George
Forum:
61-77 GTO, Tempest & LeMans Parts WANTED
07-18-2023, 07:24 PM
2
Power Antenna Switch
824
Posted By
tri.lllgto
69 was last year of power antenna Pontiacs
Forum:
07-16-2023, 05:23 PM
2
Windlace question
816
Posted By
rolling money pits
Long ones are roof rail, the 90* looking ones are...
Long ones are roof rail, the 90* looking ones are rear window and other two should be upper windshield…although the one I yanked off mine was joined, I think, by a skinny 3 inch long or so piece.
Forum:
Ames Customer Satisfaction Forum
06-25-2023, 08:47 PM
20
Ridiculous shipping
4,537
Posted By
Jim Zeek
bitching about a couple bucks shipping in a...
bitching about a couple bucks shipping in a multiple thousands of dollars hobby. SMFH
Forum:
05-17-2023, 04:04 PM
2
Trunk Latch Finish
1,303
Posted By
OG68
The key operated latch was installed before...
The key operated latch was installed before painting so the exposed end will have body color overspray.
From my understanding, the electric trunk latch will be natural as it was installed after...
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
12:40 PM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
