#41
Old 09-21-2016, 09:13 PM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
I have two sets of these heads. They are good quality castings. A basic copy of a RAIV is what I would call them. The chambers suck. The valve positions suck for a big bore, big valve. Their ability to increase CSA sucks. The LS3 heads on my GTO KILL compared to an out of the box Ehead.
Marcella doing the work to Leech's heads and delivering their numbers speak TON's to their ability. They have polished a turd to the MAX, well done guys. I can only assume max welding and intake ports encroaching into valve covers?
  #42
Old 09-21-2016, 09:39 PM
Anderson Port Development's Avatar
Anderson Port Development Anderson Port Development is offline
I agree that would be interesting. Do you have "off the clock" access to a dyno at Sonny's?
... ummm, probably not, both of our dyno's stay very busy, Sonny's might wanna kill me for bringing my little Pontiac turd in there, lol ...
... but once my 572 is ready, i will ask him ...
  #43
Old 09-21-2016, 09:40 PM
john marcella john marcella is offline
Nope. No welding no guides moved just ported. Pretty straightforward stuff. Only welding I've done on those Heads is when Mike decides to disassemble the motor the fast way.
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
  #44
Old 09-21-2016, 09:42 PM
... anything done to the chambers ?? ... i thought i might have seen a lil' sumthin'-sumthin' on the bore-scope ...
  #45
Old 09-21-2016, 11:04 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
CV1TTFMF!!!
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #46
Old 09-22-2016, 02:58 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by Old Goat Racer View Post
... Did that not start in late 1954?..
You could say that it started then, but I'd say it first proved itself in 1957 at the NASCAR Daytona SpeedWeek- finishing 1st/2nd/3rd in class through the flying mile, 1st/2nd in class in the standing start mile, and 1st in the GN race.
  #47
Old 09-22-2016, 03:15 AM
pontibeast's Avatar
pontibeast pontibeast is offline
As long as we are on the subject, what head is better for a reliable 600-700HP street/strip car, the Edelbrock or KRE's if they are both flowing close to the same CFM? Is one easier to buy at a medium level and then step up later with additional port work and cam change.
  #48
Old 09-22-2016, 08:12 AM
Are you talking about the dports or rpms vs Hiports? If you are referring to d ports. The Kre version is superior than the edelbrocks...not sure on the other..
  #49
mike leech's Avatar
mike leech mike leech is offline
100% stock locations other than pushrod holes. Hell they still have the factory iron seats in all but 3 spots. Poor number 3
Da truff. Poor no 3
All we did was make them slightly less gross same dumb spark plug location same blahh camber.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #50
Old 09-22-2016, 08:29 AM
... Definitely these round port style heads, yeah definitely for sure ...
ID:	437167   Click image for larger version
  #51
Old 09-22-2016, 08:42 AM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Most any of the available casting (Edel, HP, CV1, RAV, even KRE Dports) can get you there pretty easily. What is more important is what vendor is setting them up. Also at that HP levels there are deals to be had by buying them used.
  #52
Old 09-22-2016, 09:10 AM
Chris Uratchko Chris Uratchko is offline
Da truff. Poor no 3
I'll testify that those things are gross. I wouldn't run that junk, but to each their own!!!
Uratchko Racing Engines
www.ure-racing.com
  #53
Old 09-22-2016, 09:12 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by Jeff Kinsler View Post
CV1TTFMF!!!
^^^liar^^^
Go fast, see Elvis!
  #54
Old 09-22-2016, 09:14 AM
PAUL K's Avatar
Why do you feel the KRE d's are superior to Edelbrocks d-port?
Go fast, see Elvis!
  #55
Old 09-22-2016, 11:49 AM
pontibeast's Avatar
I would say the D ports are more in line with my budget as long as I could get the 455 into a 600-700 HP range and still have the option of stretching them out some down the road as far as streetable flow. From my limited understanding having a crazy high flowing head is not necessarily the best head to run on the street with a gear like a 3.55 and a mild 3000 stall converter. Power in the mid range seems to me to be as or more important for a car that will be mostly a street car but also raced some on the weekends.
  #56
Old 09-22-2016, 08:14 PM
Hey don't talk about pontiac junk like that.
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #57
Old 09-22-2016, 10:42 PM
pastry_chef's Avatar
You can drag a Brodix headed BBC down the track with a Performer RPM street head.
BS
I don't know any Pontiac's with "RPM street heads" that run 9.90s on pump gas at 3800 lbs.
The Brodix is a 270 oval - out of the box.
  #58
Old 09-23-2016, 10:58 AM
PAUL K's Avatar
Originally Posted by pastry_chef View Post
BS
Sorry you didn't get the memo. Off the top of my head there is one in Kansas that goes 9.80's with RPM's.
BTW. ... Brodix makes more than one head for a BBC.
Go fast, see Elvis!
  #59
Old 09-23-2016, 04:46 PM
I would be very curious to see some specs on the Pont.
Suspect car is light or running race fuel, SS trim etc.
Yup, Brodix makes a big pile of different heads for BBC.
The Chevelle is 3680 lbs with driver not 3800 as I believed.
505 with 10.5 compression
UDHarold 255/263 @ .050 solid roller.
Brodix race-rite oval.
RPM intake.
http://www.dragtimes.com/Chevrolet-C...slip-5251.html
The selection of heads available is what kills many, they decide to bolt a massive port on. Then they are stuck running 11s. LMAO.
  #60
Old 09-23-2016, 05:39 PM
WARPed's Avatar
WARPed WARPed is offline
Originally Posted by Elarson View Post
The e-head broke open the market for aftermarket Pontiac heads. People were finally able to lust for something other than collectors item RA4's. It's since been eclipsed by newer designs but you can never take away its contribution to the hobby.
Same comments about the Indian Adventures IA-1 blocks.
Eric
X3 , without E heads I believe we would not have anything close to what is available for us today. The second best thing were aftermarket blocks.
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
