Old 04-02-2014, 11:52 AM
Jim Zeek's Avatar
Jim Zeek Jim Zeek is offline
Originally Posted by Rob B View Post
He was having a few minor issues
I knew I should have told him not to go to breakfast with you
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial
http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1
  #62
Old 04-02-2014, 12:07 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
LOL!
  #63
Old 04-02-2014, 12:38 PM
Rob B's Avatar
Rob B Rob B is offline
Based upon the deep notes he was releasing while setting everything up, those "issues" weren't far behind.
I tried to get them to go there but he didn't have the time! I remember how much you enjoyed it.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
  #64
Old 04-02-2014, 05:13 PM
David Holmberg's Avatar
Patiently waiting...
  #65
Old 04-02-2014, 06:38 PM
??????????????????????????? The Number??????????????????
TV
  #66
mike leech's Avatar
mike leech mike leech is offline
Small issue today will be Back on Dyno Tuesday
Hurt a main bearing very minor issue
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #67
Old 04-02-2014, 06:45 PM
GTO Dan's Avatar
Unfortunate but that is just a sign it will really kick a$$ and run the number next week.
  #68
Old 04-02-2014, 08:47 PM
Interesting. Would have been the last thing I would have expected to read about with Tony's normal oiling mods he does.
Good luck next week.
TV
  #69
Old 04-02-2014, 09:13 PM
The sassy ones are always worth the wait.
Good luck Mike!
  #70
Old 04-02-2014, 09:43 PM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
Good luck Mike!
... that sounds like a line from a Prince song ... lol
  #71
Old 04-02-2014, 11:44 PM
mike leech's Avatar
? not familiar.
EHTTFMF!
  #72
Old 04-02-2014, 11:55 PM
mike leech's Avatar
Thanks to all who posted and texted today. We had a water leak early due to bolts that were too long on the motor plate causing a water leak. On warm up it caught the rear of the rear main against the fillet adjacent to the oil deflector. with the bearings I ran last year there was no issue. this year i changed bearing mfr acd it was an issue. The crank is already polished and ready for reassembly. i only need to replace the rear main bearing and we are up and running.
TV
since this is dwights old crank it does have tony's mods....just not by me.
Good luck Mike!
this one is feisty for sure when we break her it'll be a good day
EHTTFMF!
  #73
Old 04-03-2014, 08:14 AM
Rob B's Avatar
At least you got it figured out and no harm done. Apparently none of the water leak back into the oil pan? Are you going to be on the same schedule Tuesday as you were yesterday?
  #74
Old 04-03-2014, 09:01 AM
slowbird's Avatar
slowbird slowbird is offline
Sorry to hear this Mike, good luck next Tuesday it'll be good day im sure
  #75
Old 04-03-2014, 09:02 AM
mike leech's Avatar
I agree. it was pissed off and it took a while to find it. guy should watch this with clevite bearings. last year no issues at all with ACL, of coarse last year i checked it and was fine before assembly. I reran rod bearings, only changed mains and checked clearance. SH
and yes same schedule rob
EHTTFMF!
  #76
Old 04-03-2014, 12:00 PM
Chris Uratchko Chris Uratchko is offline
Building engines is awesome...... (cough)...
In a perfect world the crank woulda rubbed on that corner for a little bit, self clearanced, the oil flow would have washed the debris away from the bearing and down into the pan, and into the filter and with the first oil change when you cut the filter you woulda seen a little debris, not given it a second thought and today you would be all smiles.
But........
Uratchko Racing Engines
www.ure-racing.com
  #77
Old 04-03-2014, 02:15 PM
60man's Avatar
60man 60man is offline
But........
Yep yep...But I haven't found a perfect world yet though. All I found was Murphy's Law..
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
  #78
Old 04-03-2014, 02:29 PM
So true....
www.ure-racing.com
  #79
Old 04-03-2014, 07:29 PM
Rusty4cyl's Avatar
Rusty4cyl Rusty4cyl is offline
Good Luck Mike. I know you will get it fixed and make a lot of noise. The ones that give some trouble usually fly.
Blown 4cyl's to the front
  #80
Old 04-04-2014, 08:07 PM
Looking forward to you beating my number mike!
TV
