Old 12-29-2022, 08:51 PM
besserspat besserspat is offline
[QUOTE=j
Edit: I will say that if Cliff recommended it, I'd give that an awful lot of weight.[/QUOTE]
You seem to have dynoed your engine, are your heads ported? CFM? We have very similar CR .
My problem is I want to run it Hybrid , and XE lobes are a little steep for a Hybrid set up, as far as I know.
Butler seems to run XE lobes still, even if Cliff was under the impression that Butler decided not to use the XE lobes anymore.
The 230-236 114 Butler roller that was offered to me is also running XE lobes. Its a little baby of a cam especially with 510-520 lift... but If im going through the trouble of running a roller Id like something at least like the Stump Puller or OF I .
