View Single Post
  #61
Old 11-15-2015, 12:18 AM
72TAMAN's Avatar
72TAMAN 72TAMAN is offline
Added the 70-74 trim codes to cowl tag decoding threads
NEED HELP, STOLEN CARS THREADS
http://forums.maxperformanceinc.com/...d.php?t=766309
70 RESTORATION THREADS
http://forums.maxperformanceinc.com/...d.php?t=650016
71 RESTORATION THREADS
http://forums.maxperformanceinc.com/...ght=heat+riser
http://forums.maxperformanceinc.com/...d.php?t=608187
72 RESTORATION THREADS
http://forums.maxperformanceinc.com/...ghlight=keepat
http://forums.maxperformanceinc.com/...d.php?t=494143
http://forums.maxperformanceinc.com/...=keepat&page=7
73 RESTORATION THREADS
http://forums.maxperformanceinc.com/...d.php?t=644339
http://forums.maxperformanceinc.com/...d.php?t=709742
70 THREADS
http://forums.maxperformanceinc.com/...highlight=1970
70 PARTS ONLY THREADS
http://forums.maxperformanceinc.com/...d.php?t=580525
71 THREADS
http://forums.maxperformanceinc.com/...d.php?t=733261
72 THREADS
http://forums.maxperformanceinc.com/...highlight=1972
http://forums.maxperformanceinc.com/...d.php?t=736820
https://www.youtube.com/watch?v=MNBk...ature=youtu.be
http://forums.maxperformanceinc.com/...d.php?t=740022
http://forums.maxperformanceinc.com/...d.php?t=625151
73 THREADS
http://forums.maxperformanceinc.com/...1973+headliner
73 TRANS AM UNIQUE FEATURES THREADS
http://forums.maxperformanceinc.com/...d.php?t=449356
COWL TAG DECODING THREADS
http://www.78ta.com/cowl.php
http://www.wallaceracing.com/interio...70-74-bird.htm (trim codes)
DEALER CODES THREADS
http://forums.maxperformanceinc.com/...d.php?t=534976
ENGINE CODE THREADS
http://www.wallaceracing.com/engine1.htm
DECALS THREADS
http://forums.maxperformanceinc.com/...highlight=1973
http://forums.maxperformanceinc.com/...d.php?t=651315
http://www.gt-37.org/gallery/main.php?g2_itemId=1129
BOOK THREADS
http://www.amazon.com/Trans-Am-Fireb.../dp/1613251726
REAR BUMPER THREADS
FORMULA HOOD THREADS
http://forums.maxperformanceinc.com/...d.php?t=780473
FRONT BUMPER THREADS
http://forums.maxperformanceinc.com/...d.php?t=780992
http://forums.maxperformanceinc.com/...a+build+primer
SUB FRAME THREADS
http://forums.maxperformanceinc.com/...d.php?t=489495
SUSPENSION THREADS
https://www.eatondetroitspring.com/o.../parts-lookup/
WHEEL RESTO THREADS
http://www.goatsgarage.com/huny2.html
http://www.forums.maxperformanceinc....d.php?t=554851
WHEEL CODE THREADS
http://forums.maxperformanceinc.com/...d.php?t=583466
http://www.tran-zam.com/1971/Wheels.html
http://www.pontiacserver.com/wheels.html
http://www.wallaceracing.com/rally-wheel-date-code.htm
WHEEL INFO. THREADS
http://forums.maxperformanceinc.com/...d.php?t=780491
http://forums.maxperformanceinc.com/...d.php?t=781379
MISC WHEEL THREADS
http://forums.maxperformanceinc.com/...d.php?t=748138
455HO THREADS
http://forums.maxperformanceinc.com/...d.php?t=538654
http://www.455-ho.com/
SD THREADS
http://forums.maxperformanceinc.com/...d.php?t=736345
http://www.angelfire.com/mi/jamos1/howto.html
http://forums.maxperformanceinc.com/...d.php?t=471844
HOW TO REBUILD PONTIAC V8 MOTOR THREADS
http://forums.maxperformanceinc.com/...d.php?t=623671
https://vimeo.com/60051620
PONTIAC HEAD THREADS
http://forums.maxperformanceinc.com/...d.php?t=636024
http://forums.maxperformanceinc.com/...d.php?t=636309
http://forums.maxperformanceinc.com/...d.php?t=534326
http://forums.maxperformanceinc.com/...d.php?t=585395
http://www.wallaceracing.com/head1.htm
EXHAUST THREADS
http://forums.maxperformanceinc.com/...d.php?t=468168
http://forums.maxperformanceinc.com/...d.php?t=550283
http://forums.maxperformanceinc.com/...d.php?t=630943
http://www.wallaceracing.com/exhaust1.htm
TRANSMISSION THREADS
http://forums.maxperformanceinc.com/...d.php?t=466818
http://forums.maxperformanceinc.com/...d.php?t=466820
http://forums.maxperformanceinc.com/...d.php?t=466821
BRAKE THREADS
http://forums.maxperformanceinc.com/...d.php?t=593740
DISTRIBUTOR THREADS
http://forums.maxperformanceinc.com/...d.php?t=652883
http://forums.maxperformanceinc.com/...d.php?t=530812
http://forums.maxperformanceinc.com/...d.php?t=479239
http://forums.maxperformanceinc.com/....php?p=5405995
STARTER AND STARTER SHIMMING THREADS
http://forums.maxperformanceinc.com/...d.php?t=780683
IDLER PULLEY BEARING REPLACEMENT THREADS
http://forums.maxperformanceinc.com/...t=Idler+pulley
MOTOR THREADS
http://forums.maxperformanceinc.com/...d.php?t=690512
http://forums.maxperformanceinc.com/...d.php?t=609229
http://forums.maxperformanceinc.com/...d.php?t=769185
http://forums.maxperformanceinc.com/...d.php?t=772995
http://forums.maxperformanceinc.com/...d.php?t=739781
http://forums.maxperformanceinc.com/...d.php?t=730569
http://forums.maxperformanceinc.com/...d.php?t=772223
http://forums.maxperformanceinc.com/...d.php?t=776003
http://forums.maxperformanceinc.com/...d.php?t=379985
http://forums.maxperformanceinc.com/...d.php?t=583733
http://forums.maxperformanceinc.com/...d.php?t=579525
http://forums.maxperformanceinc.com/...d.php?t=593983
http://forums.maxperformanceinc.com/...d.php?t=556933
FUEL SYSTEM THREADS
http://forums.maxperformanceinc.com/...d.php?t=779232
CARBURETOR RESTORATION THREADS
http://www.vintagemusclecarparts.com/
AIR CLEANER BASE, FILTER, SCOOP THREADS
http://www.forums.maxperformanceinc....d.php?t=699820
CAM THREADS
http://forums.maxperformanceinc.com/...d.php?t=765522
http://forums.maxperformanceinc.com/...d.php?t=770467
SHEET METAL AND BODY THREADS
http://forums.maxperformanceinc.com/...d.php?t=773122
http://www.forums.maxperformanceinc....d.php?t=528624
http://www.forums.maxperformanceinc....d.php?t=750558
http://forums.maxperformanceinc.com/...30#post5466030
PLASTIC VALANCE THREADS
http://www.forums.maxperformanceinc....d.php?t=730042
http://www.forums.maxperformanceinc.....php?p=3331725
DASH THREADS
http://www.78ta.com/resto/rdash.php
VINYL REPAIRS THREADS
http://www.drvinyl.com/
INTERIOR THREADS
http://www.buickperformanceclub.com/...lumnwobble.htm
http://forums.maxperformanceinc.com/...d.php?t=514465
http://forums.maxperformanceinc.com/...ding+seat+belt
http://forums.maxperformanceinc.com/...d.php?t=570786
http://forums.maxperformanceinc.com/...d.php?t=781255
http://forums.maxperformanceinc.com/...d.php?t=781226
JACK AND SPARE THREADS
http://forums.maxperformanceinc.com/...d.php?t=780059
PLATING COMPANY THREADS
http://www.paulschrome.com/
http://www.tricityplating.com/
OUR 70-73 PARTS GUY NORWOOD THREADS
http://forums.maxperformanceinc.com/...r.php?u=141593
ANDRE
1972 TRANS AM , UNDER RESTORATION
http://forums.maxperformanceinc.com/...d.php?t=656067
1972 FIREBIRD FUTUR PROJECT
http://forums.maxperformanceinc.com/...d.php?t=674551
1978 TRANS AM (PARTS CAR) MAYBE
1971 LEMANS T37 (PARTED OUT)
1976 TRANS AM (PARTED OUT)
1984 6000LE (SOLD)
2003 SILVERADO 1500
